turbo technics v6 starting problem
Old Sep 14, 2014 | 03:40 AM
tonysierra4x4's Avatar
tonysierra4x4
Default turbo technics v6 starting problem
hello all. my sierra 2.8 v6 turbo has a starting issue. when left for a few days it takes a while to start the engine seemingly due to fuel issue. when ignition is on there is no power at the pump, but it comes on when starter engaged. it then takes a lot of cranking to actually start the engine. i have tried a lead direct from battery to pump and this still doesn't make a difference. when restarted after an hour or so all seems fine. any ideas would be a great help.
Old Sep 14, 2014 | 09:35 AM
YOREVOL's Avatar
YOREVOL
YOREVOL
fuel pump relay should kick the pump in to prime the system. its the purple one under the nsf kick panel iirc.
Old Sep 14, 2014 | 10:02 AM
tonysierra4x4
thanks. will check it
Old Sep 14, 2014 | 11:41 AM
tony66's Avatar
tony66
Default pressure
system should keep pressure-you must be losing it somewhere...pump[sprung non return valve iirc]possibly an injector passing fuel[worth tugging them out plus the cold start once switched off]
brilliant cars the 2.8 t/t
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
