Mk1 Focus TDDI ABS issue?
Old Sep 8, 2014 | 05:27 PM
Slaney21's Avatar
Slaney21
Roflmaowtfbbqhax!
Default Mk1 Focus TDDI ABS issue?
Evening all
over the past week or 2 i have noticed an issue with the breaking at different intervals. The other day i had the ABS and Traction light appear on the dashboard, but yesterday they flickered off. After doing some quick googling, the main things i am finding is that the abs sensor in the wheel (bearing?) Needs replacing or it's the speed sensor?
I also read that taking out the fuse for the ABS can be done but alters the braking ratio causing the car to become dangerous. is there any truth in this?
Any help will be greatly appreciated
regards
Lance
Old Sep 8, 2014 | 05:43 PM
RichieST's Avatar
RichieST
Don't remove the fuse. See if F-Super diagnostic program is compatible with your car. It's available cheap enough on ebay and reads ABS codes.
Old Sep 8, 2014 | 07:12 PM
anthony lea's Avatar
anthony lea
Ford allegiance
Originally Posted by Slaney21
Evening all
regards
Lance
Had this on mine. Changed the front sensors and still did it. In the end I disconnected the rear sensors at the plug part which were full of dirt. Sprayed with electrical contact cleaner and then when reconnected wrapped in insulation tape. That was over a year ago and not happened since.
Old Sep 8, 2014 | 07:36 PM
focusv8's Avatar
focusv8
You'll need it fixed for the next MOT.
Get diagnostics on it, don't throw money at it guessing.
Old Sep 8, 2014 | 07:46 PM
Slaney21's Avatar
Slaney21
Roflmaowtfbbqhax!
Ok guys cheers. Car has 10 months left on the MOT so ok on that part. Cars been good to me so far so hopefully nothing too major. Will try the rear plug thingy tomorrow if there's a lad from MT who is free to help lend their workspace.
will go looking for the F-super jobbie as well. Again, many thanks guys
Old Sep 8, 2014 | 07:50 PM
anthony lea
Ford allegiance
Might as well clean the front plug connectors too?
Old Sep 8, 2014 | 08:38 PM
Slaney21's Avatar
Slaney21
Roflmaowtfbbqhax!
Will do matey
Old Sep 8, 2014 | 08:41 PM
j6kyt's Avatar
j6kyt
totally agree
Old Oct 3, 2014 | 10:22 AM
Slaney21's Avatar
Slaney21
Roflmaowtfbbqhax!
Sorry for bump but just an update to say it was a loose driver side driveshaft! Found out after changing a tyre.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
SteveyDee
Aug 24, 2015 05:43 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
