Any converted 4x4 saff to 2wd
Old Sep 8, 2014 | 06:13 AM
3doorcozmess's Avatar
3doorcozmess
Default Any converted 4x4 saff to 2wd
Hello
Has any one here ever converted a 4x4 saff to 2wd??
What's involved and what's the cost
Si.
Old Sep 8, 2014 | 06:22 AM
DangerousBryan's Avatar
DangerousBryan
Not done one but guessing front hubs,sump,gearbox,front brakes,clutch and propshaft will all need changing.
Old Sep 8, 2014 | 08:21 AM
doga-ot's Avatar
doga-ot
Yes depends if you can get a deal on job lot of stuff!
Front hubs, front shocks and springs, front brakes, gearbox, prop shaft, sump, rear diff, subframe, power steering rack just from memory may be 1 or 2 more things
Old Sep 8, 2014 | 11:32 AM
Fezman1's Avatar
Fezman1
I know of a 4x4 converted to 2wd, whereby they kept the 4x4 front end set up and just had the outer driveshaft cups machined back.
So in theory it can be done with just sourcing a box and prop. -if your happy to keep the rear end with 7"diff.
All depends if you want it done cheap or you want it done exactly as the 2wd setup.
Old Sep 8, 2014 | 11:51 AM
The Crocodile Hunter's Avatar
If i was going to do it i would just keep the 4x4 front end
Old Sep 8, 2014 | 04:55 PM
Fezman1's Avatar
Fezman1
Yeah, I cant see anything wrong with doing it that way.
Maybe change the spring rates, geometry set up & away you go.
Old Sep 8, 2014 | 07:28 PM
RSCossieGaz's Avatar
RSCossieGaz
Im currently converting my smokestone blue saph to full 2wd set up.Ive gone the full conversion using everything from 2wd like front hubs,crossmember,TCA,brakes ,steering rack,konis,T5 gearbox,propshaft,rear beam,7.5 diff etc etc
Old Sep 9, 2014 | 09:57 AM
peteh's Avatar
peteh
As gaz says, also 2wd sump and oil pick up if you wana get rid of the 4x4 sump and diff.
Old Sep 9, 2014 | 10:04 AM
Jay,'s Avatar
Jay,
Sponsor
Totally wrong everything is wrong to set it right you would spend more money to adapt everything to adjust to the spec thats required than it will cost to how its done correctly bellow
Old Sep 11, 2014 | 08:16 PM
gingeRS's Avatar
gingeRS
You need to change the lot, getting rid of the 4x4 box and linkage and replacing with a t5 means a better drive, rwd fun and big power with no reliability problems
Old Sep 13, 2014 | 06:56 PM
nick46's Avatar
nick46
VR46 The G.O.A.T
Apologies if this is a stupid question! But why would you want to convert 4WD to 2WD?
Were the 4WD Cossies rubbish or something?
Old Sep 13, 2014 | 06:57 PM
nick46's Avatar
nick46
VR46 The G.O.A.T
Or did the 4WD system just sap too much power?
Old Sep 13, 2014 | 07:04 PM
james kiely's Avatar
james kiely
nick some people just prefer the way 2wd s drive, and some prefer some tail out action
Old Sep 13, 2014 | 07:33 PM
nick46's Avatar
nick46
VR46 The G.O.A.T
So why not just buy a 2WD? Or are there not many left now?
Sorry if I'm coming across as a bit of a plank but I just don't get it. I used to love the Cossies when I was growing up (still a fan now!), but I've never driven either of them. Maybe if I had, I might see why people want to do it.
I mean, I've never heard of anyone wanting to convert their Scooby or Evo to 2WD?
Old Sep 13, 2014 | 08:22 PM
scoooby slayer's Avatar
scoooby slayer
I agree it seems completely illogical to me on a saph, I understand it on an escos as they were never made rwd.
there will no doubt be more 4x4 shells available and in better condition as there newer and no doubt not so abused, still a lot of pointless work imo unless its a mental specced one then its irrelevant as it built from the ground up anyway.
Old Sep 14, 2014 | 08:19 PM
mark r's Avatar
mark r
You can use 4x4 pick up and oil pump with a little fettleing on. 2wd sump
Mark
Old Sep 15, 2014 | 08:22 AM
Because if you want to run high power/torque levels the std 4wd transmission is not anywhere near as strong as the rwd.
Basic choice is go rwd or spend Ł3k+ on a 4wd box
Old Oct 9, 2014 | 04:56 PM
3doorcozmess
I've been looking for a 2wd cossie for ages there not coming up any more breakers have pulled them apart. standard ones pop up from traders for silly money but there are some good spec 4x4 out there so maybe my only option.
I had a escort cosworth and my pals has a saff with 30 bhp more and he flu passed me because the 4x4 transmission loses to much power.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
rog
Sep 16, 2015 03:00 PM
Neil Clark
Sep 8, 2015 07:06 PM
