Help Cosworth headbolt washers to big?
Old Sep 7, 2014 | 07:06 AM
3drRich's Avatar
3drRich
Default Help Cosworth headbolt washers to big?
As above gone to put my head back on yesterday and the washers on the headbolts are slightly to big to fit down inside the head on my 3dr?
There standard headbolts from Matt Lewis but would I be right in saying they might be for a 4x4 head?
Old Sep 7, 2014 | 07:31 AM
The Crocodile Hunter's Avatar
Weren't the early 3 door heads different to the 2wd saph heads too?
Might be mistaken? Sure someone knows for definite
Old Sep 7, 2014 | 07:35 AM
POLARIS ESCOS's Avatar
POLARIS ESCOS
You need to ask for the smaller washer ones they were only fitted to the early 3drs iirc they are 21mm instead of 23mm
Old Sep 7, 2014 | 09:16 AM
costina's Avatar
costina
Live long and prosper!!
late 2wd heads used later bolts same as 4x4. as said above 3dr uses smaller type.
Paul
Old Sep 7, 2014 | 07:09 PM
BRAMMER's Avatar
BRAMMER
Get them turned down or GGR sells them but they are more expensive Ł45.96 as the very first cars had the small head as mines one of them sure it was something like the first 200
http://shop.grahamgoode.com/cylinder...61-62607-p.asp
Old Sep 7, 2014 | 08:48 PM
3drRich's Avatar
3drRich
Cheers for your help guys. Does anybody know what the washer size is? Burton have head bolts with washers at 22.85 and 21.45mm so assuming I need the smaller of the 2?
Old Sep 9, 2014 | 05:35 PM
BRAMMER's Avatar
BRAMMER
Yes mate they are 21.5mm
Old Sep 10, 2014 | 08:08 PM
3drRich's Avatar
3drRich
Cheers guys all sorted now.
skypeller
Sep 19, 2015 09:58 PM
borboyous
Aug 22, 2015 11:17 AM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
Blown Hell
Aug 5, 2015 07:22 AM
