Escort Cosworth idle problem
Old Sep 4, 2014 | 09:50 PM
shoppel's Avatar
shoppel
Default Escort Cosworth idle problem
I got a problem with the idle. Can not set it up right. Engine is hot, valve unplugged. No air leaks! Car runs on 1600 rpm not under this. When it will go down it directly goes up to 1600rpm. With no irc!?!? I can not find the failure....any ideas?
Setup:
3bar map
Green Bosch
-31 actuator
Msd chip
Old Sep 5, 2014 | 11:32 AM
James @ M Developments.'s Avatar
Although the ISCV is unplugged it may still be bypassing air if its stuck open.
An engine will not rev without air, so one way or another air is bypassing the throttle.
Old Sep 5, 2014 | 01:39 PM
shoppel's Avatar
shoppel
I have put the valve out and closed the hole in the trottle. So the valve can not be the problem I guess. Can the tps cause such a problem?
Old Sep 5, 2014 | 02:37 PM
The TPS will only cause the ISCV to open when it sees a throttle angle, if the valve is shut/disconnected this cannot be the issue.
Maybe your throttle plate is not closing? or the base idle screw is not seated correctly. otherwise you must have an air leak somewhere.
Old Sep 5, 2014 | 08:22 PM
shoppel's Avatar
shoppel
Have checked the tps to ECU closed 580ohm.
How can I check the voltage? Where do I have to measure and how?
Old Sep 5, 2014 | 09:23 PM
botters's Avatar
botters
competant bodger
http://www.bigturbo.co.uk/
Old Sep 6, 2014 | 09:01 AM
shoppel's Avatar
shoppel
Read this allready. The question is where to check the voltage? At the connector with ignition on? It is hard to reach it because there is no room in the engine bay....
Old Sep 6, 2014 | 10:03 AM
martysmartie's Avatar
martysmartie
The TPS is not the problem, as James said!
The problem is the throttle is not closing correctly, or you have an air leak, as said.
Martin
Old Sep 6, 2014 | 11:54 AM
shoppel's Avatar
shoppel
Throttle closes fine. I have put in the stock map sensor...car runs fine at idle...??????
Old Sep 6, 2014 | 02:00 PM
shoppel's Avatar
shoppel
....but richer at full throttle. Afr 11.3
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
James Porter
Aug 26, 2015 10:51 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
