Custom Gear Ratio Manufacturer
Old Aug 29, 2014 | 12:13 PM
Sonic Boom's Avatar
Sonic Boom
Default Custom Gear Ratio Manufacturer
Just an idea at the moment and wouldn't be implemented till after the end of the race season but does anyone know of company that would cut me a custom set of ratios for the T5 Gearbox?
The current selection of ratios available aren't really what i'm after and i'd like to fine tune a set to engine output.
I know one off manufacturing isn't cheap, but this would make a real difference to the way car performs on a Hillclimb.
Cheers Rich
Old Aug 29, 2014 | 12:40 PM
nixon_2wd's Avatar
nixon_2wd
Wouldn't Quaife help you out?
Old Aug 29, 2014 | 12:55 PM
Beetlejuice's Avatar
Beetlejuice
DJM Motorsport should be able to sort you out
Old Aug 29, 2014 | 06:29 PM
stevieturbo's Avatar
stevieturbo
C**t
DJM above would be best local option
GForce in the states already offer some ratios
http://www.gforcetransmissions.com/tran_gt-5.asp
http://www.gforcetransmissions.com/t-5_ratio.htm
Samsonas do some "universal" rwd dog and sequential gearboxes with a variety of ratios
http://samsonas.com/?page_id=234
Universal seems to mean a BMW fitment with an adaptor.
I think SQS used to do some T5 stuff, but havent seen anything listed for some time
http://www.sqsracing.com/aktuality
A diff swap not get you near where you need to be ? Certainly be a lot easier and cheaper ?
Or try and hunt down a Tractive gearbox ?
Old Aug 29, 2014 | 07:47 PM
Sonic Boom's Avatar
Sonic Boom
I am thinking about fitting the 4.3 CWP but there will always have a long 1st.
Got to stay a T5 casing (due to regs) can do what ever I want to the internals (can't put sequential in thou)
I'll give DJM a look thou
Rich
Old Aug 29, 2014 | 07:55 PM
stevieturbo
C**t
Long first is great !
Or are the hills really tight ?
But a long first typically means the actual gearset will be much closer spaced so better for racing with a narrower power band. Likewise fitting a shorter diff will have a similar effect. Just be careful you dont go too short and end up spending all day changing gear. That's fine with a sequential, not so much with a synchro box unless it is pretty slick.
Gearboxman does some stuff too
http://gearboxman.co.uk/infot5.html
http://www.5speeds.com/t5/s80.html
http://www.carcraft.com/howto/116_0609_t5_transmission/
Old Sep 2, 2014 | 11:20 PM
stu21t's Avatar
stu21t
elite racing transmissions
they were going to make me a complete gearbox for sensible money a whiole ago.
Old Sep 3, 2014 | 09:25 AM
packman's Avatar
packman
Try these they do car related stuff as well.....
http://www.novaracing.co.uk/History.html
Old Sep 3, 2014 | 09:44 AM
stevieturbo
C**t
From most searching Ive done over the years...usually the word "Elite" is followed by the word "problems"
Old Sep 3, 2014 | 06:20 PM
markk's Avatar
markk
Alan Young engineering can hob.
Great bloke to speak to, for one off pairs expect around £700 plus vat.
Don't bother ringing the Q word mfr.
The T5 ratios will be fine on your car mate with the 4.3.
Old Sep 5, 2014 | 06:54 PM
Twellsie's Avatar
Twellsie
These guys are worth a call http://www.depe.co.uk/?gclid=CPCxuNrfysACFUXLtAodvCsAyw
wowk
Mar 30, 2021 07:49 PM
Iain Mac
Sep 30, 2015 09:39 PM
