mk 5 escort 1.6 cvh engine swap to 1.6 rs turbo
Old Aug 29, 2014 | 10:48 AM
ganleyman22's Avatar
ganleyman22
Default mk 5 escort 1.6 cvh engine swap to 1.6 rs turbo
so basically I have a mk 5 1.6 cabriolet and have just bought a 1.6 rs turbo engine and wanted to know if it was a straight swap, I also have a chipped ecu for my new engine, will I need a new loom or can I use the old one? is there anything eles I need? thanks
Old Aug 29, 2014 | 12:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
To put it as concisely as I can and assuming it's an MFI engine... You need everything from the RST engine bay/car including the loom's and ECU's and then a fuel pump for the MK5 that will flow enough fuel ( I have never fitted one to a MK5 so no idea what it has a standard).
Old Aug 29, 2014 | 02:02 PM
ganleyman22
its a efi engine and so is the rs turbo engine, all that is different I think is just the turbo and manifold and there both cvh too.
Old Aug 29, 2014 | 08:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What ECU does your Cabby use? If it's an OFAC/OFAB then might just be a case of swapping ECU's, injectors, manifolds, etc.
JoeyBoyden
Jan 4, 2024 02:36 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
vdubo7
Aug 2, 2015 08:17 PM
