Escos High Revs Problem
Old Aug 10, 2014 | 04:14 PM
stecozz's Avatar
stecozz
Default Escos High Revs Problem
Set my Pf09 Tps today to 0.35volts and it revs to over 2000rpm! at idle.
Even when i screw the idle right in it make hardly any difference,the only way it will idle is for me to set the tps at around 0.15v which is wrong isnt it?
Any help greatfully received
Old Aug 10, 2014 | 04:59 PM
oldford's Avatar
oldford
0.15 Volt is perfect. Anything between 0.06 and 0.29 is acceptable.
Old Aug 10, 2014 | 05:04 PM
stecozz's Avatar
stecozz
Was always told that 0.35v was how it had to be, confused now lol
Old Aug 10, 2014 | 05:51 PM
oldford's Avatar
oldford
Then you have been told wrong. You even proved it yourself, by setting the tps to 0.15V.
The idle position will be learned by the ecu, but within limits.
Below 0.05V is an error and above 0.30V is considered partial load - not idle.
Old Aug 10, 2014 | 06:13 PM
stecozz's Avatar
stecozz
Many thanks, guess you gotta learn as go along
TPM961
Jan 15, 2018 10:50 AM
RSmark84
Sep 13, 2015 01:29 PM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
