Ok so i want to powder coat my cross member up but can i remove it from the car with the engine still in? The car is currently sitting up on axel stands.
I used a large block of wood to spread the load and a trolley jack to hold engine while I removed member then blocked up on the engine mounts.
put a big plank of wood across the stut tops and chain it to the engine arms an d pick up points
then remove the 4 bolts for the crossmemeber, but don't forget the rack and in some cases the brake lines might go through some of the bits on the side in some cars
