RS turbo.. Desperate Help required..CUTTING OUT
Hello ,
Sorry to come in with anther 'its cutting out ' problem but i'm really annoyed at it now..
long story short : 86' Series one RS , rebuilt , standard ECU's , new dizzy , leads etc.
Was running / driving but now its cutting out , sometimes after 1 minute sometimes after 10 but it always starts.
12v direct to Coil - checked - still cuts out
Wires wiggled - still cuts out
No obvious air leaks / broken pipes.
Im starting to think metering unit maybe ? odd that seems to be linked to pressing in the clutch pedal tho.
If anyone can help i would be very greatfull ..or if theres a contact local to portsmouth ill happy pay for some expert help.
i can provide more details if that helps.
Thank you very much, Pete
hello , yes i believe it could well be .. if it is it must be a cheeky one because im struggeling to find it..
anyone have any tips on where they are ? i know theres a few around the engine bay and kick panels .. seems so be a wiring issues ..the revs flick sharply on occasion
When it won't start, does it have a spark? Hall sender failure possibly (in the distributor)
edit - Didn't see you had a new dizzy
Does it have fuel?
Need to know what it's losing before guessing which bits to fit..
Does it have fuel?
Russ Payne
Sep 25, 2015 08:29 PM
BlackSaff
Oct 28, 2004 04:50 PM
