What brakes for standard sapph wheels
Anyone on here run bigger brakes on standard 15"wheels?
My sapph is a way off being finished but want to keep original wheels if possible, every sapph I see has comps or similar and I've been there on my last one.
Will be stage 3 to start with and may see a little track use at the ring so better brakes are a must
Yeah looks like anything decent will be hard to find, I know an AP kit fits but don't know how good it would be standard size, expensive too and the last AP setup I had wasn't as good as I thought it should be
Looks like anyone with standard wheels must be running standard brakes, apart from ap setup I've found nothing, might have to go that way.
I'm pretty sure someone does a kit that runs bigger discs and std calipers. There a brackets to raise the std calipers. Speak to martin Holland when he is back on the 11th.
K sport do a kit, listed on ebay for 4x4 but im sure they would do a kit for 2wd.
http://www.ebay.co.uk/itm/K-Sport-Fr...ht_3006wt_1275
Says not for Rs, must be worth more than the car they will be fitted to then
Let me know what they say,
I have the same problem been looking for a kit to fit under 15's on my cortina. I not really sure if its worth spending big money on a kit when the disc size is limited to 305mm, not really sure if the extra braking force comes from the calliper or increased disc size. I know the 330mm Ap kit is very common on cosworths and every one says how there so much better than standard.
I was told by a very experienced tuner use Ap or don't bother, just run std callipers with good pads.
Easy on a Cortina almost anything will fit. I have had 283mm cosworth 2wd discs with mondeo single piston calipers which worked well. under 15"s. Then I had focus RS discs and calipers under 18"s and now run 350mm and brembo calipers from a Porsche.
Pug 406 coupe brembo calipers have the same hole spacing as a Cortina and can use a 280mm ish disc for a great set up.
Take a look at this
http://retrorides.proboards.com/thre...7#.U-c7_z90x6o
Take a look at this
Take a look at this
I am using sierra cosworth front legs/hubs and have 2wd 4pots & std 285mm discs, I think the route to my poor brakes is the shit OBP peddle box im using.
Karl 3dr
102
Oct 14, 2016 08:17 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
