Focus mk1.5 rubber splitter
Old Aug 1, 2014 | 05:45 AM
marky_g's Avatar
marky_g
Fleet Manager
Default Focus mk1.5 rubber splitter
How the fuk do you remove it!!!! Mines bent from when it was put on the recover truck and seems to have got worse in the heat
Need to replace it to tidy it up but no clue where to start
Old Aug 1, 2014 | 06:32 PM
3i Jim's Avatar
3i Jim
10 Year Member
You'll struggle to do it on the car. Remove the front bumper and lay it down on a work bench, make life a lot easier to remove. They simpley pull off. The fun begins putting the new one on! Once you've centralised the new splitter to the bumper, using a club hammer and gently tap the splitter into place. It's not easy and It can be a two man job. I've done loads over the years.
Old Aug 1, 2014 | 06:56 PM
RichieST's Avatar
RichieST
AS said, not too hard to remove but a nightmare to fit the new one. Have you tried heating the original one up with a hot air gun and seeing if it will go back in to shape?
Old Aug 1, 2014 | 08:47 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
mine came off really easy to be honest. all i did was get some lift off oversteer on a track day and hit a cone and off it came.
Old Aug 1, 2014 | 11:04 PM
marky_g's Avatar
marky_g
Fleet Manager
I've tried a heat gun in the past on a different car but not this one, think I'm also going to struggle to find a mint one
155lee
Oct 27, 2015 04:55 AM
richierich1986
Sep 18, 2015 03:29 PM
Chopshop85
Sep 12, 2015 06:42 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
hopper350
Sep 4, 2015 12:53 AM
