Secs monitor
Old Jul 25, 2014 | 09:39 PM
saphcoz31's Avatar
saphcoz31
Saphcoz31
Default Secs monitor
Hi all, Just wondered what is more accurate for reading my boost level as my secs monitor reads about 3psi less than my boost gauge, I'm peaking at 29psi on secs but 32psi on gauge just be nice to no as with the hot weather I would rather it be 29psi.
Old Jul 26, 2014 | 08:26 AM
nicksaph's Avatar
nicksaph
i would have said the secs monitor is more accurate as it is rearding what the ecu sees.
analogue gauges can be notoriously inaccurate.
cheers nick.
Old Jul 27, 2014 | 09:38 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
My secs on idle says -12 and boost gauge says -25 but both above 0 read roughly the same. Secs is more accurate.
Old Jul 28, 2014 | 08:43 AM
James @ M Developments.'s Avatar
29psi is more than likely the max reference of the 3 bar map sensor, if you ran 60psi of boost the secs would still show 29.
Old Jul 28, 2014 | 07:34 PM
saphcoz31's Avatar
saphcoz31
Saphcoz31
Thanks for your replies guys as James says I think it is the max it can read from the map sensor, Cheers for your help.
pabloXR
Sep 21, 2015 12:42 PM
Roscopeco
Sep 14, 2015 05:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
K42L
Aug 28, 2015 01:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
