Flooding
Old Jul 20, 2014 | 09:47 PM
bill1962's Avatar
bill1962
Default Flooding
My 3dr 1986 Cosworth keeps flooding. It has been in the shed for 12 years but starts and runs fine sometimes, then just keeps flooding. Take the plugs out and you can see the petrol filling the bores!
Old Jul 21, 2014 | 10:55 AM
tony66's Avatar
tony66
Default flooding
is the fpr passing fuel into the manifold?
or are injectors staying open..
Old Jul 21, 2014 | 11:36 AM
bill1962's Avatar
bill1962
The fuel is in the bores so may be the injectors staying open?? I am in darkest Donegal in Ireland so no one to take her too.
How would I check it out myself!!!!!! I'm OK with tractor engines!!!
Thanks for your help
Old Jul 21, 2014 | 01:34 PM
tony66's Avatar
tony66
Default fuel
fuel can get in the bores via the fpr too-it fills the inlet manifold sucking fuel via the burst diaphragm
cheap fix if it is-well for a cossie lol
injectors can stick open with ecu/driver issues etc-an ecu is cheap now too
have a wee check of the fpr vac pipe...
edited to add it could be a short on injector wire-earthing it out keeping it open the minute igniton is on
Old Jul 21, 2014 | 05:08 PM
bill1962's Avatar
bill1962
Thanks for the info I will have a look at the weekend when I get home and let you know how I get on.
fordsportjay
Dec 7, 2005 05:26 PM
doggydowg
Oct 4, 2005 10:24 PM
vroooom ptssssh
53
Jul 16, 2005 11:25 AM
james_birch
Jan 9, 2005 12:06 PM
Uncle Henry
Aug 10, 2004 08:41 PM
