mk 4 rst mfi over fueling
Old Jul 13, 2014 | 07:21 PM
fatdavezz's Avatar
fatdavezz
Default mk 4 rst mfi over fueling
hi i am crrently bald due to scratching my head for so long my series 2 rst will not start im gettin way to much fuel ive changed the metering head but still loads of fuel plugs are drowned please help
Old Jul 13, 2014 | 07:30 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
have you tried unplugging the cold start
its the blue plug in the middle of inlet the one that has a red pipe from metering head,
Old Jul 13, 2014 | 07:35 PM
fatdavezz's Avatar
fatdavezz
removed plug still no good
Old Jul 13, 2014 | 07:55 PM
mk2grp1's Avatar
mk2grp1
under the air filter check the brass disc moves freely, with ignition off
then with ignition on push flap very briefly should hear the injectors whine
then remove spark plugs completely and tuck leads towards servo number them first if you know they are in the correct positions lay a rag over the spark plug holes,
but not plugging them, just catching any petrol splashes you might get shortly
then remove fuel relay crank for 10 seconds clearing the cylinders of fuel,
sling the rag out the way , let the vapours die down ,
give it 10 minutes or so leave fuel relay disconnected then plug in spark plugs and check all spark by cranking report back
Old Jul 13, 2014 | 09:09 PM
fatdavezz's Avatar
fatdavezz
got good spark on all plugs if i remove fuel pump relay it will start up for a few seconds and run
Old Jul 13, 2014 | 09:36 PM
mk2grp1's Avatar
mk2grp1
what happened under the air filter or did you not bother
Old Jul 14, 2014 | 01:37 AM
rs_turbo_tony's Avatar
rs_turbo_tony
on the rear of engine left hand side . if your facing engine there is a white wiring plug goin to thermo time switch . check.that sensor is in good working order. you can buy these from motor sport developments.
Old Jul 14, 2014 | 05:04 PM
fatdavezz's Avatar
fatdavezz
dont have a white plug
Old Jul 14, 2014 | 09:04 PM
rs_turbo_tony
yellow sensor / switch
Old Jul 15, 2014 | 11:54 AM
fatdavezz's Avatar
fatdavezz
ill have a look
Old Jul 16, 2014 | 08:01 PM
fatdavezz's Avatar
fatdavezz
changed yellow plug on inlet still no good if i unbolt cold start sensor it doent spray any fuel i removed my injectors and they all seem to fire out fuel in sequence but there seems to be a awfull amount of fuel spray out
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
20/20 vision
Sep 29, 2015 11:27 AM
