Do I / Don't I ?
Just after some advice....
mk4 fiesta .... 2.0 zetec turbo.
coolant temps are fine when moving, but if I get stuck in any traffic the under bonnet temps are so high that it makes the coolant temp rise quickly. It's all such a squeeze in there that I think any little bits to get the hot air out may help so I've got some bonnet vents. Obviously they will sit flush when done, but just wanted some opinions before I cut the bonnet!!
Thanks, Matt
Thanks, Matt
Thanks for the input. The Angel eyes are turd but were cheaper than standard ones after I had a little kiss with a Peugeot. I quite like the mirrors.... maybe that's just me
I'll try a different fan and stat maybe.
Thanks, Matt
Thanks, Matt
Any way of chopping the bumper out and getting a larger radiator/fan setup in, yes chuck on some vents but be careful, had some louves cut into my car bonnet of my old 205 track car which looked ok but still on a hot day didn't do a great deal to help.
Position the vents in line with the edge of the front grill towards the rear of the bonnet. Then use a deflector plate on the front grill to direct air over the top of the engine this will cause the hot air to be pulled away from the engine bay and out of your vents.
Mk1 FRS owners have been doing this for some time and seen a good reduction in temps.
I would also advise a low temp stat and alloy radiator.
rsguy
44
Sep 29, 2015 03:29 PM
