Annoying rattle (well the most annoying one anyway)
Old Jun 25, 2014 | 09:09 PM
stewarthannah's Avatar
stewarthannah
Default Annoying rattle (well the most annoying one anyway)
Along with all the others that go with an old car an annoying rattle has started from the inside of my drivers door, and was wondering how easy is it to take the door cards off too have a gander? Thanks
Old Jun 25, 2014 | 09:20 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
mk3 easy and mk4 very easy
Old Jun 25, 2014 | 09:34 PM
stewarthannah
Is it just removing the window rubber and the 4 screws down the sides? What about the door handle and window buttons does it come off around them? Sorry getting bit dark to have a proper look now
Old Jun 25, 2014 | 10:17 PM
mk2grp1's Avatar
mk2grp1
yes do the side screws, front and back
gently prise out window switch and disconnect plug, (could do this after handle trim)
prise out handle trim from base, flat blade screwdriver, gently wiggle the remaining part upto the switch end, revealing 2 or 3 cross head screws, undo them
handle off, now pop switch ot from underside, does less damage if ham fisted, then you have opening catch trim, open handle to get at screw, guide off that piece, theres a cover cap at front of door pocket, prise out with tiny flat blade
then your almost done, gentle tugging on sides and top panel will slacken off
then you lift panel up over the catches on lowest edge,
obviously if I`ve missed out any sighted screws remove them from the card,
don`t lose anything and you reverse the process to refit
Old Jun 25, 2014 | 10:18 PM
mk2grp1's Avatar
mk2grp1
theres a screw under the door pocket cap ,
Old Mar 1, 2023 | 02:48 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I know this is an old thread, but did you every resolve the noise ?
Fudgey
Sep 17, 2015 01:06 PM
tib2220
Sep 14, 2015 12:33 PM
bassboy
Sep 10, 2015 08:54 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
