Webcon fuel pressure regulator fitting
Old Jun 25, 2014 | 06:09 PM
GREENRS's Avatar
GREENRS
member
Default Webcon fuel pressure regulator fitting
Having a problem fitting this one from msd, can't fit it with the original ford oe bracket, the inpipe is too long and its mounted 5mm too high so unable to fit onto the fuel rail on my 2wd Sapph, the only way I can see to fit it is to make a custom bracket,
Anyone else had this problem?
Old Jun 30, 2014 | 11:56 AM
opposite lock's Avatar
opposite lock
Get something made up and zinc plate it .
I switched my regulator not long ago and found the bracket didnt fit, I just connected the pipe and let it sit in situ.
Not ideal I know but it worked for the short term.
Old Jun 30, 2014 | 03:27 PM
James @ M Developments.'s Avatar
I normally make a new bracket to fit them onto, they are as close as you will get to the OE fitting one these days.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
mrmann
Aug 20, 2015 11:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
Zoggon
Aug 10, 2015 10:39 AM
