Double din stereo fitting?
Old Jun 20, 2014 | 01:31 PM
leep27's Avatar
leep27
Default Double din stereo fitting?
Hi. I have the mk3 face life mondeo. I recently bought an alpine double din stereo to replace the std one. I bought the ISO patch lead and a facia panel. Here's the problem, my new stereo is slightly bigger than the hole in the facia! Are these things not a std size? Anyone know if there's a solution to this as I don't wanna get rid of my new alpine. Cheers.
Old Jun 20, 2014 | 03:24 PM
foxy06's Avatar
foxy06
It depends on the Stereo you removed, was it the in dash Sony 6 disc unit? If so, they have a slightly different shape to a normal stereo at the top, and the Mondeo centre console is shaped to fit it, you either remove it to cut a section where top of stereo fits or source another console using the standard Ford stereo.
Old Jun 20, 2014 | 03:32 PM
leep27's Avatar
leep27
Hi. Thanks for replying. What is on it now is the standard ford 6000 CD. The later one that is part of the console. As I say I got a facia adapter plate. But my cage is too big for the hole in it. The cage does fit in the hole without the original stereo in it. I just winder if there are different types of facia plates? Can't see why that'd be tho. Not if the stereos are all std sizes.
Old Jun 20, 2014 | 05:57 PM
dojj's Avatar
dojj
Resident Wrestling Legend
There are 3 different dash layouts depending in what was fitted
The complete centre console may need changing as they come with standard 6000 fitment, sony fitment and satnav fitment
The autoleads adapter onky supports the 6000 fitment head unit
Old Jun 20, 2014 | 05:58 PM
dojj's Avatar
dojj
For what its worth i fitted a merc cage to mine when i fitted it with double din so moan to alpine
Old Jun 20, 2014 | 06:28 PM
leep27's Avatar
leep27
It's the auto leads facia I got. So you're saying not to use my alpine cage? What a can of worms this is turning out to be.
Old Jun 20, 2014 | 09:55 PM
dojj's Avatar
dojj
it took months to sort my one out, and it still fits a little wonky
either the sony or the 6000 facia is deeper so you can get more "stereo" into the slot, but the aperture sizes may also differ as the sony versions came with different fitments and angles depending on which cars they were fitted to, they also came in the focus and galaxy and aren't interchangeable hence the difference in the shape of the facia panels
Old Jun 21, 2014 | 06:15 AM
leep27's Avatar
leep27
Well as I say the unit fits in the hole but the issue seems to be the auto leads facia is too small for my alpine cage! So is there not a bigger facia available on the market or some other kind of conversion? Or is it a butchering job. Can't believe they sell the gear to change the stereo but it won't actually fit anything. Looks like I'll have to stick with the std and sell my new one. Gutted. 😟
Old Jun 21, 2014 | 06:46 AM
dojj's Avatar
dojj
It will fit, its just an arse of a job
Old Jun 21, 2014 | 11:13 AM
foxy06's Avatar
foxy06
Fire some pics up of everything if you can.
But as Dojj says, there is 3 variations for the Mondeo Mk3 and all have different applications due to stereo design/shape used by Ford.
Also, if you google Double DIN fitting for mondeo mk3 etc you will get loads of threads on TalkFord and ST Drivers etc of other lads who had issues and had to cut or faff about with fascias etc, some recommend buying a universal cage but cant remember the exact dimensions off my head.
Old Jun 21, 2014 | 12:01 PM
leep27's Avatar
leep27
How do you get pics up on here? I'd be happy to put on what I can once I know how to. Cheers.
Old Jun 21, 2014 | 12:15 PM
leep27's Avatar
leep27
http://i1291.photobucket.com/albums/b558/Leep27/Mobile%20Uploads/image_zps7145aa10.jpg
http://i1291.photobucket.com/albums/b558/Leep27/Mobile%20Uploads/image_zps9d4393a9.jpg
http://i1291.photobucket.com/albums/b558/Leep27/Mobile%20Uploads/image_zps387ca3d3.jpg
http://i1291.photobucket.com/albums/b558/Leep27/Mobile%20Uploads/image_zps58aeda7d.jpg
Old Jun 21, 2014 | 12:44 PM
dojj's Avatar
dojj
Originally Posted by leep27
like that
Old Jun 21, 2014 | 02:53 PM
leep27's Avatar
leep27
lol. Well done sir. Us technotards do struggle with these things. Thank you tho.
Old Jun 26, 2014 | 07:23 PM
leep27's Avatar
leep27
Success at last. What a chew on tho. Universal cage bought and the hole at the rear hacked out. Never again. Still need to trim the surround a bit but overall I'm happy. Thanks for the advice and comments given.
[/IMG]
Old Jun 26, 2014 | 07:28 PM
leep27's Avatar
leep27
Any leads out there to get this working off my steering control stalk? Is it possible to do this??
Old Jun 26, 2014 | 08:35 PM
dojj's Avatar
dojj
if you have the quad lock then each different section is allocated to different things and yes you can get adapters that simply plug in
you just have to see if your radio is one that is listed
but well done in giving it a go
Old Jun 26, 2014 | 08:46 PM
leep27's Avatar
leep27
Cheers. I was bricking it when I committed to the hacksaw. Bit the bullet and got stuck in. Quite proud of myself. Yeah it's a quad lock. I did notice empty spaces in it and wondered.
Old Jul 7, 2014 | 10:38 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Have a look at Connect2 Patch leads - they'll almost certainly do one that will allow the steering column switches to work.
Old Jul 7, 2014 | 10:47 AM
leep27's Avatar
leep27
Ta for that. I got a 2nd hand one off eBay for a bargain 99p. It is a connect2 one too. It works ok. Bit slow to react tho. Other than that it'll do.
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
borboyous
Aug 22, 2015 11:17 AM
salsheikh
Aug 20, 2015 12:33 PM
salsheikh
Jul 30, 2015 08:45 PM
