oil change question
Old Jun 16, 2014 | 09:40 PM
tony66's Avatar
tony66
Default oil change question
does anybody on here use pump to extract engine oil when doing a change?
its a method i have been employing for a while now and i am a bit of a convert to it..i know some cars dont empty well with this method though
and some[4g63/vags etc] get more out using extraction
Old Jul 10, 2014 | 11:01 PM
tony66's Avatar
tony66
Default oil removal
anybody?
Old Jul 11, 2014 | 06:47 AM
Harryh24's Avatar
Harryh24
I use it on boats and have some cars. makes life a lot easier.
Old Jul 11, 2014 | 10:13 AM
tony66's Avatar
tony66
Default extraction
it does indeed-can anybody tell me if it will suitably extract all the oil from a 2wd yb sump?
Old Jul 11, 2014 | 10:40 AM
Colin_P's Avatar
Colin_P
I've use one on my VAG 1.9 TDI for years and can get more oil out that way as I can suck it out of the oil cooler which doesn't happen on a gravity drain.
Cannot help on the YB
Old Jul 11, 2014 | 11:08 AM
tony66's Avatar
tony66
Default oil
yes-its great,i am a late convert to this but have now used it on a variety of cars
however i need to be sure i empty the sump-heres why
the cossie i have is a 2wd with 200 block but the stick is the one with the round plastic end..i dont know what dipstick tube has been used either
at the moment the sump has been overfilled-on the stick anyway[by almost the same amount of measure as is on it-if accurate maybe as much as 1.5 litres]
now-having had a disaster years ago[about 18 lol] with a newly bought converted[2wd-to 4wd car as was the fashion then] which showed full on stick due to wrong parts used but in reality only had about 2.5 litres in it when i cornered enthusiastically it ran the crank
i suppose i will just need to warm it up and drain it off-replacing it with around 4.5 litres -then see what it reads on the stick and mark it..was just wondering if the suction method completely emptied it -i suppose i could suction then remove plug to see whats left
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
StephTell
Sep 2, 2015 06:31 PM
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
