PAS pump mount
Old Jun 14, 2014 | 02:03 AM
wattie's Avatar
wattie
Default PAS pump mount
Should there be a gasket between the power steering pump mount and the block where the old pinto mechanical fuel pump is run from, can't find a gasket for it in the set, don't want to put it on this now incase it leaks, took the engine apart over 2 years ago and cent remember if there should be one there , cheers
Old Jun 14, 2014 | 04:37 AM
I think when I fitted mine I used some silicone sealer. It was that long ago im not 100% sure though lol.
Old Jun 14, 2014 | 06:41 AM
cossie moon's Avatar
cossie moon
Durham RSOC member
Yes it needs a gasket
Old Jun 14, 2014 | 07:29 PM
wattie's Avatar
wattie
Cool cheers , didn't know if the hole was blocked off inside with the cossie blocks , guess I'll make a gasket then , cheers !
Old Jun 14, 2014 | 08:19 PM
Paul_RS's Avatar
Paul_RS
Silicone is fine.
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
