hydraulic clutch 4x4
Old Jun 12, 2014 | 08:45 PM
eel-roy-t5r's Avatar
eel-roy-t5r
Default hydraulic clutch 4x4
where is the best place to buy the conversion , I don't fancy paying the over the top , or will I have to use ebay , any 1 also carry out the conversion local to the north east
cheers
Old Jun 12, 2014 | 09:12 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I'm going to use the reyland kit on mine. It's tyres and tested and you know it's going to work
Old Jun 12, 2014 | 09:25 PM
BigErn's Avatar
BigErn
People say to use E30 BMW parts. Im sure theres a few folk on here done their own conversions by now, someone will know what bits to use.
Old Jun 12, 2014 | 10:03 PM
BRAMMER's Avatar
BRAMMER
When you put all the parts in front of you theirs nothing to it all all.
E30 BMW slave cylinder http://www.ebay.co.uk/itm/CLUTCH-SLA...item2ecf1ed877
Girling master cylinder .625
copy part http://www.ebay.co.uk/itm/0-625-allo...item2588c6b005
Genuine part http://www.ebay.co.uk/itm/Girling-Ra...item5664597a96
Reservoir bottle http://www.burtonpower.com/parts-by-...re-112009.html
Other than that you need the small fittings for the master cylinder and slave but a trip to hydraulic specialist should be able to match the fitting and connecting hose between the 2 cylinders - for the bottle i just used cotton over braid
Theirs enough threads on here to give you info on drilling the pedal and modding the box
then you need to get the bellhousing modded to suit which cost's roughly £100
and a small female fitting needs to be welded to clutch release arm what the push road from the slave houses in.
Old Jun 12, 2014 | 10:06 PM
ajamesc's Avatar
ajamesc
Only reason I'm going for the kit is ease as it comes with the bits to mod the pedal box and plate to renforce the bulk head
Old Jun 12, 2014 | 10:16 PM
Jay,'s Avatar
Jay,
Sponsor
Its a bit of 2mm plate Andy thats all and a rose joint and spacers
I used a E30 slave and a .70 master cylinder and a fluid pot from thik the whole lot cost £70 and I used a .70 as it bleed easier and a better pedal feel on the heavy clutch I have made a stencil of the slave plunger and mounting holes and drilled the box out
Old Jun 12, 2014 | 10:19 PM
ajamesc's Avatar
ajamesc
I may pop up your place then jay and look at your pedal worse case I can cut my own plate as we have loads of stainless at work. It's just the pedal I'm un sure on. If it's just two spacers I can make them as we have a lath at work too
Old Jun 13, 2014 | 05:36 AM
cozzy jeff's Avatar
cozzy jeff
My resto thread shows how to do the pedal
Old Jun 13, 2014 | 06:34 AM
Jay,'s Avatar
Jay,
Sponsor
Yeh thats where i got my info from From Jeff tip top illustration
Old Jun 13, 2014 | 08:21 AM
natehall's Avatar
natehall
I'm doing this to mine with the parts from above.
Old Jun 13, 2014 | 09:05 PM
eel-roy-t5r
so good info lads , cheers , and cheers for the links , where did you lads get the braided hose from then ??
eel-roy-t5r
and the car is 4x4
Old Jun 13, 2014 | 09:12 PM
ajamesc's Avatar
ajamesc
I did my pedal box today. Going with a wilwood .70 master and bmw e30 slave. I'll get the bottle from eBay and there's a company in Basingstoke that supply's fittings and makes braided lines as I'll be using a alloy bottle and aero quipping everything
Old Jun 13, 2014 | 09:32 PM
natehall's Avatar
natehall
How far down is the 8mm hole from the top or are there any good marks to ensure the fulcran point is right?
Old Jun 13, 2014 | 09:41 PM
ajamesc's Avatar
ajamesc
I took the measurements from cozzy jeffs from above's resto thread. He did the hard bit and the working out jay from above did the same as well
Old Jun 14, 2014 | 05:51 PM
eel-roy-t5r
thanks lads , any got a link for the other bits that's needed for the job , av got the master cylinder, slave cylinder and bottle ordered from ebay , am after the bits to go on the slave to the clutch fork and the master cylinder to the clutch pedal
cheers
Old Jun 14, 2014 | 05:56 PM
ajamesc's Avatar
ajamesc
I'm going to measure the rod on the slave then get a bit of bar a little wider drill into it just larger than the slave rod. Cut it down to about 10mm and weld it to the fork. As for the rose joint order one off eBay the same thread size as your master then get a clevis pin to go throug te pedal
Old Jun 15, 2014 | 08:11 AM
andycozyboy's Avatar
andycozyboy
hi mate I used a land rover master cylinder which has a fixed pot on top of it ,and ran a copper pipe across builk head down to a flexi pipe to a land rover slave cylinder .all you got to do is shave the corner of your gearbox down where it look likes fins and drill a hole for slave cylinder,and line a bolt up with clutch fork and weld a nut on fork so bolt dosnt drop out .bleed the clutch and happy days this all in all cost me about 18.00 pound and it works a treat. ps am running about 380 bhp with transit hd clutch don't get ripped off with paddle clutch prices.
Old Jun 15, 2014 | 11:53 AM
smithy rs2k's Avatar
smithy rs2k
Does anyone do these conversions them selfs be willing to do mine for me on a 4x4 saph ? I'm in Leicestershire but don't mind travelling
Old Jun 18, 2014 | 07:36 PM
eel-roy-t5r
okay . just started to receive the bits I ordered , what do I need to do to the clutch fork so the slave arm doesn't move under pressure
pics would be great
cheers
Old Jun 18, 2014 | 07:55 PM
ajamesc's Avatar
ajamesc
pics would be great
cheers
Get a bit of bar 10mm long drill into it just larger than the slave rod so the rod can sit into it. Weld that to the clutch fork
Old Jun 18, 2014 | 08:11 PM
eel-roy-t5r
Get a bit of bar 10mm long drill into just larger than the slave rod so the rod can sit into it. Weld that to the rod
cheers bud , easy as that then lol
Old Jun 18, 2014 | 08:18 PM
ajamesc's Avatar
ajamesc
Edited that post weld it to the clutch fork lol so the rod sits in it!
Old Jun 18, 2014 | 08:20 PM
Jay,'s Avatar
Jay,
Sponsor
Its a bad pic but this is all i have
Old Jun 19, 2014 | 01:47 PM
eel-roy-t5r
jay I cant see on that pics its to dark lol , al figure something out
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
