gearbox gear jumping out
Old Jun 9, 2014 | 07:55 PM
luxembourgrst's Avatar
luxembourgrst
Default gearbox gear jumping out
well on my s2 I have BM quick shift installed
an when im in the 2 gear an want to switch to the 3 gear is difficult and scratch an high rpm
at low rpm no problem the 3 gear goes good in
also from the 4 to 3 gear no problem
it always scratch fom the 2 gear to the 3 gear when trying to put the 3 gear in
and also on the motorway at the 5 gear at low rpm sometimes the gear jump out
strange? thanks
Old Jun 10, 2014 | 07:07 AM
haz87's Avatar
haz87
Either worn box, or very poorly aligned linkage.
Old Jun 10, 2014 | 03:01 PM
luxembourgrst
how to aligned the linkage correctly?
Old Jun 11, 2014 | 12:04 PM
mentalasanything's Avatar
mentalasanything
Put it in neutral
Disconnect the linkage
Put the gearbox in 4th manually: find the centre point, push the rod all the way in
Get someone to hold the stick in the position you'd hope to find 4th i.e. straight towards the back of the car
Tighten it up and test you can find all gears
Lee
Old Jun 13, 2014 | 04:06 PM
luxembourgrst
I did it with the rear gear
mjonathan24
Oct 29, 2015 10:39 PM
The Youth.
Sep 30, 2015 09:59 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
