Which wheel nuts for cosworth alloys??
Old Jun 8, 2014 | 10:03 PM
wedge07's Avatar
wedge07
Default Which wheel nuts for cosworth alloys??
Mine are defo too small so which do I need if anyone can help?
Old Jun 8, 2014 | 10:11 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
sierra collars on escort bolts, try car accessory shop or euro "crap" parts
Old Jun 8, 2014 | 10:13 PM
wedge07's Avatar
wedge07
I have old nuts off my st220 and there a lot bigger? Will they do?
Old Jun 8, 2014 | 10:14 PM
wedge07's Avatar
wedge07
Also how would I get collars off?
Old Jun 8, 2014 | 10:23 PM
mk2grp1's Avatar
mk2grp1
I mean the collars need to be bigger than rst ones,
mate got some over the counter for cosworth wheels on a mk2 orion
you can get the rst ones off with a hacksaw but up to you
over the counter should be possible
Old Jun 8, 2014 | 10:27 PM
wedge07's Avatar
wedge07
Ok mate I'll ring euro Tomoz. I know there was a company that could make them up from nuts n threads but properly. I was going to see if somewhere could do the same but using my st220 nuts as there alot bigger Thant Rst ones. If you get me? Cheers anyways mate
Old Jun 8, 2014 | 10:35 PM
kingbx95's Avatar
kingbx95
Might be wrong but i think what your probably after are ghia wheel bolts.
Should be able to get them from eBay. Got mine from my local oval race track supplier.
Old Jun 9, 2014 | 08:33 AM
studabear's Avatar
studabear
Pretty certain in the past I've read on here that speedshack sell them?
Old Jun 9, 2014 | 08:59 AM
kingbx95's Avatar
kingbx95
Good call! That defo rings bells with me too
Old Jun 9, 2014 | 09:02 AM
marky_g's Avatar
marky_g
Fleet Manager
I did a stud and nut conversion rely easy drill all the holes out to 12.mm and the studs pullin into the hubs I used an old steel wheel but some Washers and an air gun
Old Jun 9, 2014 | 10:01 AM
wedge07's Avatar
wedge07
Do the studs just tap in? I'd go for that mate as my threads in hubs are ancient so at least it would all be new etc . Couple of bolts just feel like they wanna keep turning after I've tightened them and that was before the cossie alloys! If you get me?
Old Jun 9, 2014 | 10:34 AM
studabear's Avatar
studabear
You ideally wanna press them or pull them in.
If you pull them in use a old steel wheel type wheel nut and 3-4 washers and tighten the nut against the washers which will pull the splines of the studs into the hubs.
Old Jun 9, 2014 | 10:45 AM
wedge07's Avatar
wedge07
Cheers mate. So drill them out with a 12 mm hss bit and pull them through. Where can I get some and what length studs?
Old Jun 9, 2014 | 03:28 PM
marky_g's Avatar
marky_g
Fleet Manager
As stu said but I used a 12.5 mm bit
Old Jun 9, 2014 | 05:13 PM
RSmark84's Avatar
RSmark84
or use a stud extractor. tighten until they no longer can thread in anymore.
JoeyBoyden
Jan 4, 2024 02:36 PM
rst-s1
Aug 23, 2015 07:56 AM
RSMK4TURBO
Aug 19, 2015 04:46 PM
cossynut2
Aug 19, 2015 11:29 AM
Aug 14, 2015 07:29 AM
