Series 1 Gearbox question
Hi guys
Can you fit a series 2 clutch kit into a series 1 gearbox
I've just bought a FRST and its fitted with a series 1 gearbox. I'm looking to fit an AP CP2000-35 clutch kit in it which is listed for a series 2. I'm running the 220mm flywheel at the mo aswell. will it fit into the series 1 box ok?
Any help greatly appreciated
Thanx
Thanx
Really you should fit a s2 flywheel as it's the lightest in std form.
Then the ap four paddle with std cover is good for around 20 psi on most cvh engines.
Anything more power or higher boost requires either uprated cover too or 6 paddle and uprated cover.
