zvh fuel pump query
Old Jun 4, 2014 | 03:16 PM
johnboy73's Avatar
johnboy73
Default zvh fuel pump query
hello,i have not long put a new fuel pump on my zvh engined rs turbo and seemed to have developed a misfire when revving it up.Have i bought the wrong pump?it is just a standard bosch replacement,should i have gone for an uprated pump?any help would be greatfully received!!!!
Old Jun 4, 2014 | 03:37 PM
haz87's Avatar
haz87
Don't say the spec of your zvh, but a standard rst pump can fuel a pretty good amount tbh so its unlikely that
Old Jun 4, 2014 | 03:38 PM
haz87's Avatar
haz87
Saying that, if its a like for like replacement and you had no issues beforehand, then the pump wont be the issue. (presume you bought it from a reputable source as there are alot of fake Bosch about!!)
Old Jun 4, 2014 | 04:03 PM
johnboy73's Avatar
johnboy73
Thanks for the reply,could I have an airlock at all?its a 2.0 Zetec bottom end.
Old Jun 4, 2014 | 04:05 PM
haz87's Avatar
haz87
Nah, it wont be that. Did you change the filter when changing the pump? Why did you replace the pump in the first place?
Old Jun 4, 2014 | 06:25 PM
johnboy73's Avatar
johnboy73
The car has been off the road for four years and the pump sounded on its last legs so replaced pump,lines,filter,tank and a brand new relay.
Old Jun 4, 2014 | 06:26 PM
johnboy73's Avatar
johnboy73
I am restoring the car so anything I have come across that's rusty,knackered or missing I have replaced
Old Jun 5, 2014 | 07:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Maybe you have disturbed something else? But I would check your are getting battery voltage to the fuel pump wiring, you will have moved this and potentially broken a few of the 25 year old brittle strands! lol Low voltage means low fuel pressure.
Old Jun 5, 2014 | 07:08 PM
johnboy73's Avatar
johnboy73
Now there's a thought,I have disturbed pretty much all of it so that will be my next port of call,thanks for that.
Old Sep 30, 2014 | 12:01 PM
johnboy73's Avatar
johnboy73
turned out that the pipe from the fuel pump to tank had degraded to the point it was kinked!new pipe,no more problems!
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
