Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Drill Bits?
Old Jun 3, 2014 | 08:43 AM
pauloopnorth's Avatar
pauloopnorth
Default Drill Bits?
Hi Does anybody have any advice on what brand a good strong - sharp set of drill bits for drilling the heads of rusty old screws and bolts is - The drill bits I already had just span around till they get that hot they smoke and make little or no impression on the items I want too drill ,So I bought a set from ebay that the description led me to believe would simply slice through the bolts and screws like a hot knife through butter But they also failed ,So now I wonder what other people who have got a bit more experience than me in this situation might recommend
Old Jun 3, 2014 | 08:45 AM
BigErn's Avatar
BigErn
Get in with a grinder wherever possible, its loads quicker. However if you do have to drill lots of heads off it will take a bit of time and probably go through a few bits. Just go to a local tool shop and get a handful of the size you require and persevere is all I do.
Old Jun 3, 2014 | 09:12 AM
BigChuck's Avatar
BigChuck
Avoid ebay, it's really pot luck what you'll get.
I'd suggest some dormer drills. I use them daily and they last pretty well. They can be expensive but worth it in the long run.
Old Jun 3, 2014 | 09:35 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
You get what you pay for lol a good set of colbolt ones is what you need and dont drill to fast and burn them out! I've a good set of dormer bits
Old Jun 3, 2014 | 10:13 AM
pauloopnorth
Ok Thanks very much for the advice ,I am giving up on the quantity over quality approach - and i'm going to buy a set of Dormer ones
Old Jun 3, 2014 | 11:35 AM
lacey's Avatar
lacey
Slow and steady with a drop of oil and they should last
Old Jun 3, 2014 | 12:00 PM
pauloopnorth
Yes Thanks mate, I will take that on board been doing a bit of research on t'web and it seems full speed fast drilling may not always be as effective as a slower more controlled action
Old Jun 3, 2014 | 02:18 PM
pauloopnorth
Very pleased to report that with using a x7 more expensive than my others carbide tipped drill bit designed for drilling into hard plate, and done at a slow speed with a drop of oil, it worked a treat and took only around five minutes to complete the job,which is a very different result to the 40 minutes of struggling and snapping normal HSS drill bits yesterday that did not make any impression on what I was trying to drill -the whole job made much worse due to it being under a car So thank you to everybody for the tips and advice
Old Jun 15, 2014 | 09:27 AM
Churtz's Avatar
Churtz
When drilling metal, it's always good to go slow, and add oil. Let the sharp drill bit cut the metal as you go.
Also, get a bench grinder and you can sharpen the drill bits as they go blunt. B&Q are doing cheap ones at the moment.
Old Jun 15, 2014 | 11:02 AM
lacey's Avatar
lacey
Also for really hard steels
You can get a carbide tipped masonry drill
Re grind it (on a green wheel otherwise it won't cut) and that will work really well to
Old Jun 15, 2014 | 10:11 PM
pauloopnorth
Again thanks for the advice - since I made the switch from cheap and cheerful to a set of more expensive dormer bits I have used them on a number of occasions now on various grades of metals with brilliant results the difference between my new bits and the cheap ones I had to keep buying in singles from my local hardware shop are like night and day
Old Aug 11, 2014 | 06:43 PM
TPM961's Avatar
TPM961
Dormer all the way. expensive but last forever! i paid £60 (half price) for a set going up in .5mm increments to 10mm, had a lot of hard use and still cut beautifully
Old Aug 11, 2014 | 08:14 PM
pauloopnorth
I have to agree ,my dormers are still a delight to use and from now on I won't waste my money on anything else
Old Aug 11, 2014 | 08:19 PM
ajamesc's Avatar
ajamesc
Best thing you can do with drill bits is also learn how to sharpen them lol.
A quick going over on the grinder and there like brand new! The amount of times I've seen guys a work burn out drill bits then chuck them away and go get another such a massive waste
Old Aug 11, 2014 | 08:23 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Cleveland Twist drills are the best ones out there. Expensive, but last for ages!! If you have a mate in the aircraft production environment, ask them to get you Boelube.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
hopper350
Sep 4, 2015 12:53 AM
