Couple of in board Practice runs today from Shelsley
Still getting to grips with the new setup it's weird actually having grip apart from off the line which needs alot of work.
Plus it's still not fully mapped probably only running 450bhp at a guess.
3rd Practice Run of the Day with best start:
4th Practice run of the day terrible bog down start but faster on all other sectors and splits, if i'd done a better start a 34 second run is on the cards:
Rich
Rich
When I started rallying I used a 3.9:1 - similar sprints, single venue and I found I just couldn't get the car to flow properly, when I went to a 4.44 the car was so much nicer to drive, and I still probably got the same top speed when using a 3.9 In the long sections.
I bet your getting prob 100+ in 3rd gear, mine tops at around 140 - and even that is too high, but I have a high ratio 5th gear.
Rich
Between £100 and £120 depends on the event
Yes mate been running the black Pro Race 1.2's all this season, you should have popped over mate always up for a chat.
Rich
Rich
Here's another video taken today from up at the top of the track by my Sister:
https://passionford.com/forum/pictur...ml#post6481331
Rich
Rich
Track was shut for over an hour, didn't finish the final run off till 18:30
Rich
It's a Road Going Class so you are meant to run all the trim, but then you are allowed to fit racing seats and harness that then causes issues with the rear seats as they get in the way of the harness so I made up a new rear bench seat out of 3/4" MDF and trimmed it.
The Scrutineers all seem to be happy with it.
Ye theres no padding lol, but been as the both front seats are fixed and the harness run through you wouldn't beable to sit there anyway
Cheers mate, yup think i'll look into a shorter final drive but the BW 7670 EFR will coem first.
Rich
Rich
kosienutter
31
Aug 22, 2015 09:55 AM
Escortdriver1
Aug 19, 2015 09:02 PM
Versus_Creations
20
Aug 8, 2015 10:22 AM
