Megasquirt wiring, bit of help pls
Wiring v1 megasquirt fresh labelled loom to black top injector loom and edis4.
Can anyone tell me does the injector feed from ecu go to no1 or no2 on injector plug?
Thanks
Thanks
As i am not running edis i am not know with that. But you mean you have two injector grounds both firing two injectors and only one driver on the megasquirt?
I installed a second driver by changing the soldering of the ms. Then you can put em 1 on 1. But guess there will be an easier solution. Probably you can connect all 4 on one cable with the right settings in ms. But double check it as i am not sure.
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
kosienutter
31
Aug 22, 2015 09:55 AM
