Immobiliser issue
Old May 29, 2014 | 03:35 PM
Neatrags's Avatar
Neatrags
Angry Immobiliser issue
Hi people I need some help I cannot get my car to start and we believe it's the factory immobiliser as the fuel pump will not run unless the immobiliser is off and I've had an auto electrician out and he agrees it's to do with the doors and how it locks and arms system we have tried several things to sort but as yet nothing seams to turn it off I can double lock it and it chirps several times when locked then double locked but not beeps or chirps to say it's off and consequently it does not turn off and does not allow fuel pump to run so it can start if anyone at all can help I'd really appreciate it
Cheers in advance and fingers crossed somebody can help me
Old May 29, 2014 | 04:00 PM
RichieST's Avatar
RichieST
Might help if you give some info as to what car it is and weather it's standard alarm/immob or aftermarket etc!
Old May 29, 2014 | 04:30 PM
Neatrags's Avatar
Neatrags
It's a escort cosworth large turbo it had an aftermarket alarm on it but that's been removed so we are guessing it's the standard factory ford alarm / immobilser causing the issue hope this helps
Old May 29, 2014 | 04:35 PM
RichieST's Avatar
RichieST
Is there a red light by the clock? When you turn ign on, light should come on solid then eventually go out. If it flashes quickly when ign is turned on then it has registered a fault.
Old May 29, 2014 | 04:59 PM
Neatrags's Avatar
Neatrags
Thank you for that and yes it has a red light by the clock so I will check that out later
Old May 29, 2014 | 05:52 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there are a few things you can try, but, as i've said in the other thread you've posted, how do we know you are legit?
get some pics up of your motor etc and we can then be more helpful
Old May 29, 2014 | 06:09 PM
Neatrags's Avatar
Neatrags
Fair enough I'll upload some first
Old May 29, 2014 | 07:16 PM
dojj's Avatar
dojj
Fair enough
Old May 29, 2014 | 07:46 PM
j6kyt's Avatar
j6kyt
I had a similar problem with my escos and was convinced the immobiliser was the fault but my auto electrician diagnosed it as the fusebox and fixed it.
Old May 30, 2014 | 11:53 AM
Neatrags's Avatar
Neatrags
I have uploaded pics of my car on the site as asked for as I'm a newbie the car had a sigma alarm which has been removed now the standard ford one is giving trouble if you double lock the car it chirps about 4-6 times but on unlock there is no chirp but car unlocks and also we have noticed the fuel pump does not run on ignition unless I go out of car lock and unlock it several times and eventually you here the pump engage and then it will start hence the question can I bypass or remove the standard ford alarm my auto electrician is back Saturday to try and resolve the issue as I've got the car I always wanted but it will only start when it feels like it hope now somebody can help me out
Old May 30, 2014 | 12:08 PM
RichieST's Avatar
RichieST
Have you checked what happens with the led next to the clock?
Old May 30, 2014 | 12:18 PM
Neatrags's Avatar
Neatrags
Hi Richie it does not even appear to be lighting up at all as i checked earlier this morning
Old May 30, 2014 | 12:34 PM
andrewmctiernan's Avatar
andrewmctiernan
was the sigma successfully removed? its not hanging in there is it?
Old May 30, 2014 | 01:04 PM
Neatrags's Avatar
Neatrags
Well I've had a good auto electrician to remove it so I hope so but there does seam to be a link with drivers door lock and the fuel pump
Old May 30, 2014 | 06:04 PM
dojj's Avatar
dojj
Remove the door card
Find the door lock barrel
around this thete will be the activator/deactivator ring
remove this
leave it wired up
with everything closed up, move the mechanics in the ring to see if things work or not
also check the bonnet switch is working by pressing it repeatedly
After several presses it should blip the alarm horn to show its ok
Old May 30, 2014 | 06:06 PM
dojj's Avatar
dojj
Thats what you are looking for
Unless its the vecta alarm?
Old May 30, 2014 | 08:16 PM
Neatrags's Avatar
Neatrags
Thankyou very much for the info I have my auto electrician coming back over the weekend so will show him your advice and I'll let you all know what happens !! Fingers crossed
Old Jun 1, 2014 | 10:16 AM
Neatrags's Avatar
Neatrags
Right people does the factory alarm cut fuel pump and starter or just the starter ? My engineer is here the only way it will start is if we put a live to pump via fuse box we have had the door activator out we have had fuel pump cut off out and still no joy any info would be great !!!
Old Jun 1, 2014 | 10:30 AM
Neatrags's Avatar
Neatrags
The only way we can get the pump to run is to put a live fused power to fuse board and it will start without no pump and just cranks
Old Jun 1, 2014 | 11:12 AM
dojj's Avatar
dojj
Does the pump prime with the ignition?
Old Jun 1, 2014 | 11:27 AM
Neatrags's Avatar
Neatrags
No it's not priming at all if we put a direct feed from fuse box to pump wire bingo without the wire nothing ! We have had the activator on lock out the fuel pump cut off out but nothing seams to kick into life :-(. Does the factory alarm do the fuel pump and starter or just the starter ?
Old Jun 1, 2014 | 11:33 AM
RichieST's Avatar
RichieST
I think you need to be checking power at the ecu etc, the fact that the immobiliser led isn't working at all is your biggest clue. The immobiliser isn't deactivating properly as it sound like it isn't working or powered up at all.
Old Jun 1, 2014 | 11:41 AM
Neatrags's Avatar
Neatrags
We can get the alarm to chirp 4-6 times on locking with key but no chirp on unlock we have checked bonnet trigger and with a few presses this chirps to indicate it's working I believe had auto electrician here 3 hours this morning and we have had everything out fuses relays and any advice we could get he did say there appears to be 2 ecu one on passenger piller in foot well which is coneected and there appears to be another up under glove box which does not appear to be connected is that right ?
Old Jun 1, 2014 | 11:59 AM
Neatrags's Avatar
Neatrags
Also does factory alarm cut the starter and the fuel pump or just starter ???
Old Jun 1, 2014 | 12:37 PM
dojj's Avatar
dojj
it may be worth simply removing the dash to look at all the potential wires that you need to look at and test
if there are multipule ecu's and you've removed one alarm, it may be that you've chopped into another wire by mistake
was it all working and running fine before the other alarm was removed?
Old Jun 1, 2014 | 12:43 PM
Neatrags's Avatar
Neatrags
No it had the same problem before removal of sigma alarm it sometimes worked but was pot luck but more often than not it wouldn't start because pump was not running off ignition
Old Jun 1, 2014 | 12:58 PM
Neatrags's Avatar
Neatrags
Also the door activator and de-activator appears to arm but not disarm where could I get a replacement to try any ideas except ford direct ?
Old Jun 1, 2014 | 02:33 PM
RichieST's Avatar
RichieST
I still think you are barking up the wrong tree!! I'd be looking at your power feeds / earths. As said above, it could well be the fuse box at fault.
Old Jun 2, 2014 | 02:54 PM
Neatrags's Avatar
Neatrags
I have sent the car away to a auto electrician to get to the bottom of the problem will report back once sorted thanks for suggestions and hints so far
Old Jun 4, 2014 | 05:02 PM
Neatrags's Avatar
Neatrags
And the results are in The fuse box needed re-soldering and a new fuel pump relay collecting the car tomorrow
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
pabloXR
Sep 21, 2015 12:42 PM
Flatlinedan
Sep 18, 2015 12:41 PM
