FRST Rocker Cover Leaking
Old May 22, 2014 | 06:03 PM
Brian's Avatar
Brian
Default FRST Rocker Cover Leaking
My mate has a FRST and the rocker is leaking at the back, it turns out one of the bolts for the rocker cover wont tighten, obviously the thread is fooked
Anyone had this before? got any ideas how we can repair it?
Cheers Brian
Old May 22, 2014 | 06:46 PM
De4n0's Avatar
De4n0
Cheers Brian
He needs to hope that it's just the threads on the bolt that's fucked, if it is then he just need a new bolt, if it's the head then he will need to re-tap it.
Old May 22, 2014 | 06:47 PM
pcbp97's Avatar
pcbp97
all you can do is first try to re-tap the thread, if not you will need to helicoil the original bolt hole. hth
Old May 22, 2014 | 06:55 PM
Johnny Knoxville's Avatar
Johnny Knoxville
He could drill it out and fit a longer bolt with a nut just to get him by. That depends on if he can get to the underside to fit the nut.
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
get a bigger bolt and get a tap, or try a cladding screw, only need to nip it up
Old May 22, 2014 | 06:56 PM
De4n0's Avatar
De4n0
Do check the bolt first though before buying taps or attacking the head
Old May 22, 2014 | 08:31 PM
gingeRS's Avatar
gingeRS
What a load of bodgers! Helicoil the head, look it up
Old May 22, 2014 | 08:36 PM
Smudge374's Avatar
Smudge374
Get a helicoil in it, it takes 5 minutes and it will be a proper job.
Old May 22, 2014 | 08:44 PM
De4n0's Avatar
De4n0
I'm surprised no one else is recommending he doesn't check it's not the threads on the bolt that isn't fucked before saying he should go and buy a helicoil kit
Old May 23, 2014 | 06:23 AM
Brian's Avatar
Brian
Cheer for the replies will check the bolt if thats okay will try and helicoil it
Cheers Brian
Mark RS
Mar 5, 2021 06:08 PM
timsrs
Nov 13, 2018 11:48 AM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
