Oil recommendation and general advice pls
Old May 18, 2014 | 12:28 PM
3dr's Avatar
3dr
Default Oil recommendation and general advice pls
A socially I will be putting my car back on the road after almost 2 years.
I will change all the fluids from front to back but would like to know what's recommended.
From fuel (that's obvious), rear diff, gearbox, radiator, brake, engine etc
Brief spec
Full blue printed lightened n balanced engine
200 long studded block
Big valve Ported head
bd10 & bd14 cams, vernier pulleys
Rs500 plenum x4 ID 1000cc injector
GT30 turbo internally gated
Mongoose exhaust
Pro alloy Rad & Cooler
Waste spark set up
Omex 600 Ecu.
Approx 460bhp
Ideally I'm thinking it would need for the plugs to be changed or gapped and would be nice to know who can map an Omex 600 Ecu.
Your thoughts please.
Old May 18, 2014 | 07:29 PM
3dr's Avatar
3dr
Originally Posted by 3dr
A socially I will be putting my car back on the road after almost 2 years. I will change all the fluids from front to back but would like to know what's recommended. From fuel (that's obvious), rear diff, gearbox, radiator, brake, engine etc Brief spec Full blue printed lightened n balanced engine 200 long studded block Big valve Ported head bd10 & bd14 cams, vernier pulleys Rs500 plenum x4 ID 1000cc injector GT30 turbo internally gated Mongoose exhaust Pro alloy Rad & Cooler Waste spark set up Omex 600 Ecu. Approx 460bhp Ideally I'm thinking it would need for the plugs to be changed or gapped and would be nice to know who can map an Omex 600 Ecu. Your thoughts please.
"A socially" don't know where that came from.
No dodgy have any ideas?
What plugs to get and what gap to set them too.
Think I might stick a set of ht leads on it.
Any idea on pricing?
Old May 19, 2014 | 09:20 AM
Ridgey's Avatar
Ridgey
I use:
Mobil 1 Motorsport oil (10w60)
Automatic Transmission Fluid (gearbox)
Millers CRX LS 75w90 NT (diff)
Old May 19, 2014 | 01:14 PM
3dr's Avatar
3dr
Thanks mate
Why would you use ATF in the gearbox?
I would have thought 75/90 was right,
Old May 19, 2014 | 06:29 PM
I use fuchs 10/50. It used to be called silkolene. Ive used it for the past 6 years.
Old May 20, 2014 | 10:02 AM
3dr's Avatar
3dr
Thanks
Any idea on plug gaps?
Old May 21, 2014 | 07:04 AM
Ridgey's Avatar
Ridgey
ATF is the recommended fluid for T5 gearbox
Old May 21, 2014 | 07:32 AM
AJC's Avatar
AJC
have you a quaife diff or is it standard?
Old May 21, 2014 | 07:59 AM
3dr's Avatar
3dr
Standard diff and t5 box.
I didn't realise ATF is recommended for the T5.
Need to know what plugs to go for and gap.
Anybody know a decent mapper for the Omex Ecu?
I've emailed and called a few places but had no response or call back.
Old May 21, 2014 | 08:31 AM
Brendan's Avatar
Brendan
struggling with reality
Red line 10w60 or pick another oil that is poly-ol-ester based.
regarding brake fluid castrol srf is very good! but expensive!
Old May 21, 2014 | 09:18 AM
timsrs's Avatar
timsrs
I used Mobil 1 10/60 but found it to thick, made tappets noisey, swapped to the Fuch 10/50 it was so much better....
Old May 21, 2014 | 09:30 AM
AJC's Avatar
AJC
Engine Oil - 10w50 fuch/silkolene
Omex - try Will Pedley?
Plugs- Ford 071 available from Matt Lewis
Old May 21, 2014 | 02:04 PM
3dr's Avatar
3dr
Thanks guys, much appreciated.
Old May 21, 2014 | 02:39 PM
Cossiemainful's Avatar
Cossiemainful
Engine: Mobil 1 5W-50 (engine runs very smooth, no noises etc.)
Gearbox: Mobil 220 ATF oil
Plugs: only motorcraft 071 (gap with wasted spark in the range of 0.7 - 1.0)
Old May 21, 2014 | 03:46 PM
3dr's Avatar
3dr
Few different opinions on the oil.
Want some good quality stuff for the drive train so shall contact oilman.
Going to pull the plugs out over the weekend, they were new with little miles before parking it up, should I change them anyway? (Can't remember what they are)
Old May 21, 2014 | 08:16 PM
3dr's Avatar
3dr
Checked the plugs tonight and I have NGK-R plugs at 025/635mm gap.
Is that good or bad?
big_Rad
Sep 15, 2017 09:36 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
track.focus'd
Aug 12, 2015 05:53 PM
