I need help, engine broken
Old May 17, 2014 | 08:18 AM
ro33's Avatar
ro33
Default I need help, engine broken
hi
I have a rebuilt engine all, with pistons WÖSSNER and kent cams Camshaft 35k
in Camshaft Kit, cam followers were coming, and these are broken, deformed by the lower, which has shredded cylinder head engine, metal chips in the oil
low are very sharp, What can be the cause?
I thought mechanical cam followers, burton power but says it is not possible, wiht kent cams 35k, Is it true? I can not? Mechanical cam follower with this camshaft?
please answer donot happened
Old May 17, 2014 | 08:33 AM
s1cab's Avatar
s1cab
Im pretty sure you can only use mechanical followers with a cam designed to be used with them. Newman for example made the camshafts and followers from the same material creating even wear to both the followers and camshaft. If you use the followers from one manufacturer and a camshaft from another chances are the materials are different, so one will be harder wearing than the other (un-even wear).
Old May 17, 2014 | 12:30 PM
ro33's Avatar
ro33
I removed the camshaft and is broken, 1000,millas and already wore
how can this be?
website where you can get some action of the cams?
for wear of the camshaft
what a way to throw money: Cry:
Old May 17, 2014 | 06:35 PM
s1cab's Avatar
s1cab
On a cvh thats not bad heard and seen them wear alot quicker its luck of the draw.
Old May 19, 2014 | 11:44 AM
ro33's Avatar
ro33
I'll buy newman camshaft Phase 4, with mechanical tappets,
you think?
Is it crap like kent cams?
I'm thinking newman Phase 4, of 286ş, I can run it on rs turbo?
need special valve spring?
Old May 19, 2014 | 05:26 PM
s1cab's Avatar
s1cab
you think?
Newmans are the best out there and are used by many. Best thing to do is phone them and explain what power you are looking at and they will then tell you what you need etc.
Old May 20, 2014 | 10:16 AM
ro33's Avatar
ro33
hi,
I have spoken with them, very helpful, I recommend the 276 ş and standard springs.
also : Clamping Tool for Adjusting Mechanical Cam Followers
which is exactly? someone has photo?really necessary?
Old May 20, 2014 | 12:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
100% necessary..... https://passionford.com/forum/ford-e...-few-tips.html
Old May 20, 2014 | 12:18 PM
ro33's Avatar
ro33
Originally Posted by Karlos G
perfect thanks
JoeyBoyden
Jan 4, 2024 02:36 PM
paceo
Feb 3, 2016 10:31 AM
Dutchfordfreak
Escort MK 5 / MK 6
Aug 27, 2015 09:02 PM
joe1979
Aug 26, 2015 05:08 PM
