Transit Connect Starter fitted to my 3 Door
After seeing a thread about the Transit Connnect starter motor fitting a Cossie and that my starter was giving the death rattle and sticking abit I thought I try it out.
It fits perfectly works a treat seems alot punchier than my old one but an asthmatic OAP cranking it over by hand would have felt punchier than my old one
It more compact and weighs 1.5kg lighter than a standard one, all in all awesome
Here's a photo not the best quality taken from my iPhone in poor lighting conditons:
And here's the link where I got it from £56 with free next day delivery bargain
http://www.ebay.co.uk/itm/TRANSIT-CO...item1e8b2fe819
Rich
Rich
Now this info has came to light, it means that from now on anyone searching for a Transit Connect starter motor on ebay, will be faced with endless cosworth, rs, rs500 tags... And will also face the obligatory RS taxation??
It is rather cheap from this fella the same starter from Unipart is £127 plus £85 surcharge unless you give them your old one.
1.8 TDCi 2002 onwards
Rich
Rich
Car Spares by me lists the same part number for all the Cosworth range, so can't see why a 4x4 would be different.
Rich
Rich
I fitted a transit connect starter which was only a couple of months old and its sheared the gear so it spins freely resulting in no starting
what could be causing this? Had it on the car less than 12 hours with 4-5 startups
saph in dorset
Aug 14, 2015 10:10 AM
COSWORLD
Aug 14, 2015 07:40 AM
track.focus'd
Aug 12, 2015 05:53 PM
