MK1 FRS gearbox conversion on silvertop
Old May 10, 2014 | 01:30 PM
grant_xr's Avatar
grant_xr
Default MK1 FRS gearbox conversion on silvertop
Currently carrying out this conversion on my mk2 xr2. Fitted new clutch, flywheel and slave cylinder today and got the starter motor fitted.
Offered up the two piece shaft from the mk1 FRS and the bracket for the shaft bearing must bolt onto the sump of the blacktop, I'm using a silvertop block so there isn't anywhere to mount it on my sump.
Has anyone else done this conversion on a silvertop so I can see how they have dealt with this?
It looks like I'll have to fabricate a bracket that mounts to the block to sort it out.
Grant
Old May 10, 2014 | 04:27 PM
crazycage's Avatar
crazycage
Grant
Use mk2 mondeo 2 piece shaft the bearing bolts to the rear of the block. Done dozens of them.
Old May 10, 2014 | 04:31 PM
grant_xr's Avatar
grant_xr
OK mate will that still bolt to a silvertip yeah?
grant_xr's Avatar
grant_xr
*silvertop ha
Old May 10, 2014 | 04:53 PM
crazycage's Avatar
crazycage
Yes mate
Old May 10, 2014 | 05:04 PM
frsjon's Avatar
frsjon
this is what you need ( crazycage did the small shafts )
Old May 10, 2014 | 05:21 PM
Mk4 Rick's Avatar
Mk4 Rick
Nice bit of kit
Old May 11, 2014 | 01:44 AM
grant_xr's Avatar
grant_xr
Nice one folks! Jon, are they mk2 mondeo shafts that have been cut and sleeved yeah?
Grant
Old May 11, 2014 | 06:15 AM
little bram's Avatar
little bram
Same as mine mine are mk2 mondeo shafts also
Old May 11, 2014 | 06:46 AM
shalon's Avatar
shalon
I had a 20mm block welded to the rear of my sump to mount the carrir
Old May 11, 2014 | 08:01 PM
frsjon's Avatar
frsjon
Grant
yes mate all 2.0 mk2 mondeo..the mount and centre shaft are as ford made them,the two small shafts are mondeo on the left sides and frst on the right sides
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Prickly_buzz
Dec 7, 2017 09:52 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jonnyenglish
Sep 21, 2015 07:31 AM
