Max boost on standard charge cooler?
Old May 7, 2014 | 03:44 PM
series_one_rst's Avatar
series_one_rst
Default Max boost on standard charge cooler?
Hi, had a little search on google but not found much set in stone.
Will a Standard charge cooler set up of a focus RS safely and efficiently deal with 20psi boost?
thanks.
Old May 11, 2014 | 07:13 AM
pee vee's Avatar
pee vee
Should be ok. Can never tell till you try. If driven Hard, obviously the charge temps will go up.
Tim B uses the standard setup with a bigger tank in the boot I think, and his gets used pretty hard.
Old May 14, 2014 | 10:21 AM
alex_boy!'s Avatar
alex_boy!
Be fine mate - I'm sure there are some up to 400hp still running the charge cooler.
If its a strong unit still then you'll be fine
Old May 24, 2014 | 12:02 AM
series_one_rst
Cheers! unsure as to whether I will fit one now but good to know.
Old Jun 8, 2014 | 05:44 PM
Stu.H's Avatar
Stu.H
It's fine. Obviously CTs will rise but if it's just for the occasional blat, no issue
They soon come back down
JK12
33
Apr 26, 2021 12:09 PM
Adam Graham
Sep 6, 2015 06:04 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
