1/10 Holden HZ Sandman Overlander PV
Old May 6, 2014 | 04:18 AM
Trini2DBone's Avatar
Trini2DBone
Default 1/10 Holden HZ Sandman Overlander PV
Hi All,
Started my scratch built Holden Sandman Overlander a couple of months ago...
Here's a link to the build thread, I can't seem to post pics directly here at this time..
http://www.scale4x4rc.org/forums/showthread.php?t=76901
Old May 7, 2014 | 06:15 PM
steve st220's Avatar
steve st220
"SNIFF MY DIFF"
Nice build, is that a Rothmans Mk2 Ford Escort I see on the shelf in the background.
Old May 7, 2014 | 06:25 PM
Trini2DBone
Hey Thanks Steve !
And yes It's a Rothmans Mk2 Escort !
Here's the build thread. I built this last year. The body was bought from retro racing in Finland. The chassis is custom. RWD live axle on leaf springs with drive shaft up the tunnel to the tranny with the motor upfront in north/south layout. Custom made chassis and interior( the seats were bought however) also has working front disc brakes!
Enjoy ! Lol!
http://www.scale4x4rc.org/forums/showthread.php?t=71407
Old May 10, 2014 | 02:29 PM
Wow there both mint. Your very tallented.
Old May 10, 2014 | 03:26 PM
Trini2DBone
Hey thanks Glen!
Old May 14, 2014 | 09:38 PM
steve st220
"SNIFF MY DIFF"
That's incredible mate, you are very talented.
Old May 14, 2014 | 11:07 PM
Trini2DBone
Thanks again Steve!
Old Nov 26, 2014 | 08:07 PM
Trini2DBone
Been doing some work on it...just haven't updated over hear as yet...lol!
Old Nov 30, 2014 | 04:20 PM
Trini2DBone
It's ALIVE!!! Short video of the hood in action...
The nose panel is just taped on so the front clip still needs to be fine tuned...
Watcha think ?
Old Nov 30, 2014 | 04:48 PM
Its looking goo.
I was expecting the bonnet to flip right up.
Old Nov 30, 2014 | 05:00 PM
Trini2DBone
Hey thanks Glen! Lol! I guess if the hinges were bigger (1/10) they might be able to spring it all the way open..! I may try increasing number the magnets just to see if that will do it...! But the initial plan was to simulate when you 'pull' the hood release...ha!
Old Nov 30, 2014 | 07:36 PM
jason_nike's Avatar
jason_nike
Very cool.
Great work
Old Nov 30, 2014 | 07:37 PM
Trini2DBone
Hey thanks Jason!
Old Dec 12, 2014 | 05:54 PM
Trini2DBone
Been working on the grille...
This is the version I'm attempting....
And where I'm at now.... Still have to strip some .5mm sheet in to 30 pieces of 1mm x 15mm strips...3 pieces to go on between each of the vertical bars...also need to make the supporting cross bars for the supports...
:blink:
Old Dec 12, 2014 | 05:55 PM
Trini2DBone
Hey guys
Got the grille done
Old Dec 12, 2014 | 05:57 PM
Trini2DBone
Finished the faux battery top... Covers the servo nicely and is removable. As you can see the 'terminals' are the the bolts that hold it in place...which means that later on when I decide to detail out the engine, if I'm doing a harness the wires can be attached to the battery...lol!
Old Dec 12, 2014 | 06:00 PM
Trini2DBone
Hey guys ...another small
Radiator is about 80% done...! Turned out pretty nice...
Still need to do the details on the upper and lower tanks, install both hose fittings, radiator cap and the side brackets for mounting it to the radiator panel...
some pics...the first one shows the original radiator for the 1:1...
Old Dec 12, 2014 | 06:01 PM
Trini2DBone
Got the radiator completed.... Made the mounting brackets like the 1:1 , but mounted it a little different...lol! Made it so it's removable, so when it's time to paint it can come out easily, get painted and the remounted...
So...gonna try to focus on getting the dash sorted..
Some pics....
borboyous
Aug 22, 2015 11:17 AM
kiwikermit
Nov 18, 2012 05:32 AM
Garethw1986
Modellers Corner.
16
Jul 17, 2012 07:47 PM
Paulzs
Modellers Corner.
Nov 17, 2011 07:00 AM
fiestamad
Feb 27, 2011 02:15 PM
