Zetec rear crank seal
Old May 4, 2014 | 04:33 PM
Semperboy's Avatar
Semperboy
Default Zetec rear crank seal
Hi guys, just took my zetec out of the anglia as i had a slight oil leak from the rear, took the flywheel off and when the engine was tipped it let oil out of one of the flywheel bolt holes! is this normal and the flywheel bolts should create a seal or is this very bad ha!
Old May 5, 2014 | 01:03 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
this is normal without any bolts to seal the holes up.
James Porter
Oct 28, 2015 12:17 PM
155lee
14
Aug 22, 2015 12:15 PM
Caddyshack
Aug 19, 2015 07:29 PM
st220kyle
16
Aug 14, 2015 06:13 AM
lockie
Jul 31, 2015 10:03 PM
