Anyone running zetec turbo in your mk3/4 escort with dry sump set up or external pump
May 1, 2014 | 03:18 PM
As title, I have bought one of 'laceys' external pump set up's but the pump is fouling my anti-roll bar. Has anyone fitted any others or know of any fitted to a mk3/4 escort with a zetec turbo ? I wanted to go for 450ish bhp but if I can't find a way i'll have to stick around the 400bhp mark. Any help would be appreciated.
May 1, 2014 | 05:25 PM
Which anti roll bar setup you using
May 1, 2014 | 05:43 PM
Quote:
Originally Posted by
luke19790_3
Just a series 2 roll bar
May 3, 2014 | 04:59 AM
Dan arrowsmith is don't no his username off hands it may be danr8t?
May 3, 2014 | 05:06 AM
I think dan has a cut up s1 alloy cross member but no arb
May 3, 2014 | 07:11 AM
Would not having an anti roll bar effect the handling alot ? Anyone know his user name ?
May 3, 2014 | 07:48 AM
alot of people say that you dont need one
i have one one mine and wouldnt run without it
i think they get away with no arb by running stiffer springs to compensate for body roll
im running a softer spring and an arb
but
im yet to test this lol
May 3, 2014 | 07:50 AM
Don't have a arb front or rear, using a mef setup
But I haven't had it setup yet
May 3, 2014 | 07:52 AM
I ain't got a arb on my cosworth but I do have the legs strapped so there is no droop but this can have its own issues
May 3, 2014 | 11:08 AM
Does anyone on an escort mk3/4 use compression struts ? like the mk1 escort where they mount to the chassis under the bulkhead ?
May 3, 2014 | 11:47 AM
May 3, 2014 | 12:15 PM
Just found that out talking to him now thanks
May 4, 2014 | 09:57 PM
I'm wanting to run the compression struts set up could you post some pic's up if you do it cheers
May 5, 2014 | 08:09 AM
luke19790_3
Can you post some pic's on mate ?
May 5, 2014 | 11:38 AM
Going up to the garage later so will get some pictures
May 5, 2014 | 11:40 AM
Just thinking but could the pump be mounted where the cvh alternator sits?
May 5, 2014 | 12:25 PM
luke19790_3
It use two threads in the black top upper sump to mount it. My alternator sits above where the pump needs to be and theres def no way of raising where the pump can sit.
luke19790_3
Nice one !
May 5, 2014 | 01:04 PM
mine should have a pretty funky set up when done
pump sits where the alt was and thats moving to run of the cam
May 5, 2014 | 01:25 PM
Sounds good
it's the way to go nice to not have to worry about oil pump failure.
May 5, 2014 | 01:28 PM
im till cvh so its not that big a worry
with mine its more the weak head
hopefully i cured that with my roller rockers
May 5, 2014 | 01:36 PM
You using the cvh alternator?
May 5, 2014 | 01:49 PM
No sir
It's a little tiny nismo type
May 5, 2014 | 02:13 PM
No is s1cab using a cvh alt on is zetec
May 5, 2014 | 02:45 PM
I right. I will wind me neck in then
May 5, 2014 | 03:00 PM
luke19790_3
Tbh not 100% i think its a zetec one
May 5, 2014 | 03:02 PM
s1cab
So its mounted under the inlet?
May 5, 2014 | 03:29 PM
luke19790_3
No under exhaust manifold. Must be cvh
Billy_RS
16
Oct 11, 2025 09:41 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
turbobill
Aug 1, 2015 08:55 PM
