What should the voltage at the fuel pump be at idle and through the rev range, thinking of getting a new loom. Wanted to check it first to see what it's at now.
I think it should read the same as the battery - alternator. It should be something between 12 and 13.8 volts. It will likely drop as the load rises, but in my opinion anything under 11 - 11.5 requires a rewiring
