How many turns of a wheel brace
Old Apr 24, 2014 | 04:17 PM
robbo9006's Avatar
robbo9006
Default How many turns of a wheel brace
I've just put my wheels back on.
18" but because I've done a Brembo mod the wheel needed a 5 mm spacer to clear the caliper.
The question is the wheel brace turns 3 x 360 deg.
This doesn't seem a lot to keep the wheel on.
It's also my track car.
What is the guide line.
I am going to put a standard nut on to check.
The nuts I am using are the long thinner type.
the car is a ST24.
It is the front wheel.
Thankyou.
Old Apr 24, 2014 | 04:35 PM
robbo9006's Avatar
robbo9006
Well it's longer stud time ,a normal nut must have turned about ten times before it reached the top of it.
I actualy thought the studs were part of the rs 300mm disc but there not so a easy fix.
Old Apr 24, 2014 | 07:23 PM
Chopshop85's Avatar
Chopshop85
I was wondering this the other day and found this:
"M12 x 1.5 pitch stud equals 8 turns of the nut (12/1.5 =8)"
However, I'm not 100% on this. Maybe someone else could shed some light.
Old Apr 24, 2014 | 07:43 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the general rule of thumb would be for the nut to be completely on the thread of the stud
Old Apr 24, 2014 | 09:14 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I fitted 5mm spacers on the front of my saff with my ap's I had to fit longer wheel studs
Old Apr 24, 2014 | 09:46 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
i asked a while back on how far a nut should be on to be safe. i was told the engineers rule is 1.5 times the thickness of the stud. so for example the stud is 10mm thick you want 15mm of nut on thread of bolt.
Old Apr 24, 2014 | 10:43 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
BS3692 states the thickness for a M12 x 1.25 nut is 10 mm so they are basing this on a minimum of 8 full threads engaged. Three turns will not be sufficient. Your studs need to be about 9 mm longer than they are now.
Old Apr 26, 2014 | 01:03 AM
robbo9006's Avatar
robbo9006
Brilliant return.
I have ordered 20mm extra than standard.
I will put a 10mm spacer on and have a bit extra.
the rears have 20mm spacer kit on so.
Thankyou again.
The Underdog
29
Sep 7, 2015 09:49 PM
bigluke200
14
Sep 2, 2015 10:35 PM
mint_s2
Sep 2, 2015 08:58 AM
robbo9006
11
Sep 1, 2015 02:10 PM
muz
Aug 1, 2015 06:48 AM
