Boost gauge
Old Apr 21, 2014 | 11:28 AM
landaqmabba's Avatar
landaqmabba
Default Boost gauge
I know it is a long shot but,
My boost gauge is leaking fluid, it was full than it leaked for a few days and stopped but it started leaking again and now it s almost half empty.
Is this fluid purchasable? what is it? are gauges refilable? where can i find the fluid?
thanks
Old Apr 21, 2014 | 10:39 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
This type of gauge are normally filled with glycerine, its used as a damper to keep the needle steady. Some are factory sealed but others have a small plug in the back so you can fill them. You can get glycerine from supermarkets, in the home baking section. Make sure you find and fix the leak before simply topping it up.
Old Apr 22, 2014 | 10:49 AM
landaqmabba
the gauge has a tap on the top, and it seems to be leaking from the front there the face of the gauge connects to the body. can these gagues be opened maybe a seal broke or something
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
