Noisy BC Gearbox
Old Apr 14, 2014 | 12:01 PM
Rogeyboy's Avatar
Rogeyboy
Default Noisy BC Gearbox
Just fitted a spare rebuilt gearbox to my car, without driving it. Its noisy on idle with the wheels off the floor and its noisy when pushing the car in and out of the garage... Like a rough grinding noise!?
Im not driving the car because im waiting for my gearbox oil to arrive, so the gearbox is dry (stupid i know). Now i know its prob why its noisy but should it be so noisy without being driven? My main concern is i dont want to waste £40 of gearbox oil in a shagged gearbox!
Old Apr 14, 2014 | 12:08 PM
lacey's Avatar
lacey
Empty vessels make the most noise
I would have thought with oil in it , it will be silenced
But I would also have thought if it is dry and your running it even on idle for to long it may cause a Bearing to fail
Old Apr 14, 2014 | 02:06 PM
HaggisTurbo's Avatar
HaggisTurbo
This is me being stupid but I would have thought the gearbox would not be moving if the car is in neutral and idling?
Old Apr 14, 2014 | 02:39 PM
lacey's Avatar
lacey
The shaft located in the clutch will be rotating which I think may make one rack of gears rotate
Then again they all maybe rotating, but just not engaged to cause drive?
Old Apr 14, 2014 | 02:41 PM
studabear's Avatar
studabear
Haggis parts of the gearbox will turn.
Roger what engine have you fitted?
Old Apr 14, 2014 | 02:51 PM
haz87's Avatar
haz87
Yes it'll be noisy, and yes internally bits will turn at idle
Old Apr 14, 2014 | 02:52 PM
haz87's Avatar
haz87
If your really worried Rog, why not fill with cheapish £15 oil, run it about, if your happy drop out a cv and refill with the good stuff?
Old Apr 15, 2014 | 11:42 AM
Rogeyboy's Avatar
Rogeyboy
Filled up with oil, still noisy when car is pushed back and forward...
Maybe once ive driven it, it will quieten down?
Old Apr 15, 2014 | 12:29 PM
studabear's Avatar
studabear
Doubt it
Old Apr 15, 2014 | 02:09 PM
GINGExR2 T's Avatar
GINGExR2 T
The shaft that goes into the clutch plate will turn as soon as the engine is turned over unless the clutch pedal is held down, so having the engine running would mean there have been dry bearings turning at engine tick over.
Was it noisey straight away.
Ginger
Old Apr 16, 2014 | 10:10 AM
Rogeyboy's Avatar
Rogeyboy
Was noisy before i even started the engine, pushing the car back and forth the box was making an odd noise...
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
