Megasqirt/efi tps wires.
Old Apr 13, 2014 | 05:10 PM
ozzy69's Avatar
ozzy69
Default Megasqirt/efi tps wires.
Can some one tell me which wires go where i have a blacktop turbo using efi inlet and ms i just need to no what wires go to the throttle position sensor i have edited the diagram to show you.Also for the idol control valve where does the other wire go on the ms?is it just an earth?
Old Apr 14, 2014 | 08:44 PM
Churtz's Avatar
Churtz
Green /brown to blue on wiring diagram
Brown to grey on wiring diagram
Other wire earthed.
Idle control valve.... Switched earth to ecu (live comes from fusebox)
Old Apr 15, 2014 | 11:25 AM
ozzy69's Avatar
ozzy69
Other wire earthed.
churtz you are a star thanks,i had the car professionally wired when it has bike bodies but had to cut the tps wire and i never had the icv hooked up thankx again.
DixieTheKid
11
Jun 6, 2020 11:20 AM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
Roosie
Aug 15, 2015 08:09 PM
adriansaleem
Aug 1, 2015 09:28 PM
