Kawasaki Carbs
Old Apr 9, 2014 | 11:14 AM
Supercat's Avatar
Supercat
Default Kawasaki Carbs
Hi Guy
I have a Tiger Supercat fitted with a 2ltr Pinto engine (205 block). The engine is standard with the exception of the camshaft, which is a Burton high torque camshaft BF134. The camshaft description is as below:-
Power band 1000-6500rpm. Valve lift .460". Duration 266deg. Timing figures 23/63/63/23. Inlet timing 110deg ATDC. Clearances .008"/.010".
I have replaced my twin Weber 45s for a motorbike set up using Kawasaki 36mm ZX6R carbs (a recognised conversion).
I anyone out there has a similar conversion I would love to know the MAIN JET size you use, plus any other help would be welcomed.
Geoff Hull
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
sridgett
13
Sep 27, 2015 06:03 PM
