Yb oil temp gauge
Old Apr 3, 2014 | 10:06 PM
nick Kirby's Avatar
nick Kirby
Default Yb oil temp gauge
Hello in just about to install a oil temp gauge where is the best location to fit the sensor ? In the sump or maybe the oil pressure switch are .
Old Apr 3, 2014 | 10:20 PM
sharky584's Avatar
sharky584
Shark conversions
hello mate in the sump is where you want it.
Old Apr 4, 2014 | 05:53 AM
William MK2 Cosworth's Avatar
The right place is the sump, but I put mine on the oil pressure switch block, along with the oil pressure gauge. It may not read correctly, but it is a lot easier to get the little block out, and thread it on a bench
Old Apr 4, 2014 | 08:32 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I got a sump plug off eBay that the sensor screws into the middle on that's the best way if you don't won't to take the sump off and got a boss fitted
Old Apr 4, 2014 | 09:14 PM
nick Kirby's Avatar
nick Kirby
Ok thanks for the reply, just thinking the oil in the sump is the return side from engine . Once the oil has gone through pick up pipe ,oil filter ,oil cooler then to the main gallery is that the true temp of the oil that should be measured ? Maybe I'm wrong
I can fit sensor anywhere as i am rebuilding the engine ready for a mk1 escort project
Old Apr 4, 2014 | 09:19 PM
cossiestu's Avatar
cossiestu
Did that on mine, but I was lucky, the sump plug is some weird, non standard 'repair', done in the past. Was just big enough to drill and tap out to take the sensor....
Old Apr 4, 2014 | 09:44 PM
ajamesc's Avatar
ajamesc
my plug hole is standard size and I got a plug off eBay that's drilled and tapped up the middle for a sensor
Old Apr 4, 2014 | 09:56 PM
cossiestu's Avatar
cossiestu
Lol this was about 10 years ago, couldn't find a pre drilled plug iirc!? Either way, mines not a std thread, so i had to drill mine out!
Old Apr 4, 2014 | 10:12 PM
sharky584's Avatar
sharky584
Shark conversions
yes mate the sump is the true oil temperature if your rebuilding the engine you mayaswel do it properly first time round.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
