18" Subs for sale brand new house club whatever
Old Apr 1, 2014 | 08:44 PM
cossie891's Avatar
cossie891
Default 18" Subs for sale brand new house club whatever
As above I have 3 barnd new 18" fane colossus 18sb subs for sale still in the boxes sealed they cost me £300 each I have never openend them but need a quick sale so they are £130 each that is a bloody bargain they are 1000 watts
The Colossus 18SB is intended for use as a high-output bass driver in multi way systems. It features a 4 inch `sandwich' inside and outside windings voice coil, immersed in a symmetric magnetic field yielding increased linearity and lower distortion. This, coupled with a large Xmax of 8.25 mm and laminated silicone suspension, ensures tight, punchy bass at high levels of excursion. The cone membrane, manufactured from polycellulose, is much stronger and more durable than conventional paper pulp alternatives. This allows the driver to combine high-sensitivity with the structural integrity required to produce undistorted low frequencies at extreme sound pressure levels. The driver handles 1000 Watts (A.E.S.) continuous and can cope with peaks in excess of 4000 Watts. This is due to advanced thermal management in the form of vented die-cast chassis and increased motor system venting. These measures effectively remove heat from the voice coil, resulting in extremely low-power compression. The Colossus 18SB exhibits 100 dB sensitivity and can deliver bass down to 35 Hz (-6 dB) in a 200 litre ported enclosure.
Old Apr 3, 2014 | 01:32 PM
cossie891's Avatar
cossie891
Bump any one interested
Old Apr 3, 2014 | 07:09 PM
stu20004x4's Avatar
stu20004x4
mk6 escort fantasist
if only you were closer!
Old Apr 3, 2014 | 07:38 PM
salsheikh's Avatar
salsheikh
your better off putting these on the talk audio forum
Old Apr 3, 2014 | 08:24 PM
cossie891's Avatar
cossie891
Stu I can get them to you mate
Old Apr 4, 2014 | 09:09 PM
cossie891's Avatar
cossie891
Guys I can ship these ok no problem
Old Apr 4, 2014 | 10:00 PM
stu20004x4's Avatar
stu20004x4
will pm you mate
Old May 10, 2014 | 03:09 PM
cossie891's Avatar
cossie891
Bump still have these
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
