Help needed please folks!!! (2wd sapph coilovers/hub issue)
Old Mar 21, 2014 | 06:51 PM
bailey1's Avatar
bailey1
Default Help needed please folks!!! (2wd sapph coilovers/hub issue)
Hi all does anyone know what the measurement around the base of a coilovers for a 2wd sapph is supposed to be as I've just brought new gas coilovers and they are much smaller than the hub I have but as far as I am aware my hubs are standard 2wd and they look ok but as said coilover is like a dick in a bucket so either I have 4x4 ones or wron hubs!!! If any has the measurements that would be great.cheers
Old Mar 21, 2014 | 07:39 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Ill measure my shocks as there standard 2wd shocks
Old Mar 21, 2014 | 08:00 PM
gingerturbo
45mm is the diameter
Old Mar 21, 2014 | 11:16 PM
bailey1's Avatar
bailey1
Top man ill check them tomorrow.cheers
Old Mar 21, 2014 | 11:40 PM
Mk4 Zetec's Avatar
Mk4 Zetec
Sorry Boyd but I wana ask u sumet. I. Got a mk 4 escort Zetec 2.0 black top and my power goes when the car warms up and if any body as got a good loom for me cud u let me no pls 😄 I'm runing it on rs 1800 festa ecu n loom pls help me lads 👍👍👍👍
Old Mar 22, 2014 | 09:57 AM
BIL N KEL's Avatar
BIL N KEL
Sounds like you have 4x4 coilys mate
Old Mar 22, 2014 | 10:16 AM
Mk4 Zetec's Avatar
Mk4 Zetec
Wa unwanted bruv
Old Mar 22, 2014 | 10:18 AM
Mk4 Zetec's Avatar
Mk4 Zetec
I was ment to say wat u mean bruv by 4x4 coilys
Old Mar 22, 2014 | 02:46 PM
gingerturbo
Yeh I'd say the same and if you can get 4x4 hubs it will handle better
Old Mar 22, 2014 | 05:26 PM
bailey1's Avatar
bailey1
Don't think there 4x4 hubs as there's no inner cv joint left in to hold bearing in they are identical to 2wd hubs I'm thinking they are 2wd sapph non cosworth hubs like a 1.8lx or something I just need to find out what they should measure then I can check against mine to confirm.
Old Mar 22, 2014 | 08:52 PM
gingerturbo
1.8 hubs are the same as 2wd cossie hubs as my saff is a 1.8 shell with standard hubs but with 2wd cosworth shocks
Old Mar 22, 2014 | 08:54 PM
gingerturbo
Your hubs are 2wd but you've bin sent 4wd coilovers
Old Mar 22, 2014 | 09:18 PM
auldy's Avatar
auldy
4x4 struts are thicker than 2wd so surely you cant have been sent 4wd ones as they wouldn't fit into the hubs??
Am I mistaken?
Auld
Old Mar 23, 2014 | 09:02 AM
Marc sierra's Avatar
Marc sierra
4wd struts are indeed thicher than 2wd, so that cannot be the case. And 2wd cossie hubs are definately not the same as standard 2wd hubs, only the struts have about the same thickness.
I think it's better to post some pics as people will recognize it then.
Karl 3dr
102
Oct 14, 2016 08:17 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
pegaz
11
Aug 9, 2015 06:40 PM
col93saphcos
Aug 7, 2015 03:21 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
