what gauges to get and best place to mount
Old Mar 20, 2014 | 10:49 PM
tlr_rst's Avatar
tlr_rst
Default what gauges to get and best place to mount
i have a boost gauge which on the dash surround mounted where the old fuel computer should be.
been thinking and looking at gauges, need to know what i need.
car is totally standard, so oil i guess, maybe a water temp gauge or is the dash gauge for the engine temp good enough. I see theres a battery one not sure on that and read somewhere a fuel pressure gauge.
let me know the essential gauges to get please
many thanks
Old Mar 20, 2014 | 10:55 PM
mgtkr1's Avatar
mgtkr1
oil temp, water temp and oil temp. imo stack ones are the nicest with the clack surround
Old Mar 20, 2014 | 10:57 PM
studabear's Avatar
studabear
Boost, Air fuel ratio and oil pressure are my choice of additional gauges.
Edit to add I'm struggling to find a good spot for the oil pressure gauge.
Old Mar 20, 2014 | 11:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
This is what I had...
Oil pressure, Oil temp, Boost, Fuel, RPM, Speedo, Water temp and a lean AFR warning light.
Old Mar 21, 2014 | 12:11 AM
HaggisTurbo's Avatar
HaggisTurbo
Cool
Hi mate, what clocks are they Karlos they look the nuts!!
Old Mar 21, 2014 | 12:40 AM
maido's Avatar
maido
wondering that myself like them alot
Old Mar 21, 2014 | 12:57 AM
HaggisTurbo
Modernizes the dash a fair bit i think
Old Mar 21, 2014 | 09:03 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Autometer Phantom II's
http://www.autometer.com/cat_gaugeop.aspx?sid=59
Here's my guide for fitting...
https://passionford.com/forum/ford-e...ls-gauges.html
Old Mar 21, 2014 | 08:25 PM
tlr_rst's Avatar
tlr_rst
A fuel air mixture gauge would be good, hows it done. i looked into it and read that you gotta drill and hole in the exhaust near the manifold add a lambda sensor, attached, weld up and thats it, apart from the full spectrum lambda sensor being expensive.
a boost, oil temp, oil pressure gauge sounds good,
Old Mar 21, 2014 | 08:30 PM
tlr_rst's Avatar
tlr_rst
Originally Posted by Karlos G
love the gauges you have fella, is that 3 pod holder a universal one from ebay or specialist fit for the escort mk4 dash?
Old Mar 21, 2014 | 08:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cheers mate, it's a one off custom made holder.
Old Mar 21, 2014 | 09:06 PM
tlr_rst's Avatar
tlr_rst
is it simple to wire up the oil gauges?
water temp goes to the temp sender, boost gauge t piece to back of inlet, what about the oil pressure and temp hows that done?
Old Mar 22, 2014 | 08:24 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Sandwich plate between oil filter and cooler.
Old Mar 22, 2014 | 08:28 AM
Rsturbowayne's Avatar
Rsturbowayne
This is what I had... Oil pressure, Oil temp, Boost, Fuel, RPM, Speedo, Water temp and a lean AFR warning light.
How much to fit that in mine bud??
Old Mar 22, 2014 | 09:37 AM
marky_g's Avatar
marky_g
Fleet Manager
I've got a boost gauge and oil pressure boost in the top f te steering cowling (got one for sale 25 quid) and oil pressure where the fuel comp was
Old Mar 22, 2014 | 09:58 AM
Rsturbowayne
Any pics??
Old Mar 23, 2014 | 08:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
A lot... the gauges on their own were around £700! lol
Old Mar 23, 2014 | 08:48 PM
Rsturbowayne
Maybe il go the easier and some what cheaper one and get 3 off the shelf gauges and a pod
Old Mar 24, 2014 | 07:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Just bear in mind you do get what you pay for with gauges, cheap £15 ebay ones are cheap for a reason, but there's no need to go as expensive as I did.... I just really liked them! lol
Old Mar 24, 2014 | 08:02 PM
Rsturbowayne
Something il see you about bud probably the end of the year, unless anything good comes up of course
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
