Looking to buy forge actuator...
Old Mar 18, 2014 | 12:55 PM
pauldonachyrs's Avatar
pauldonachyrs
Default Looking to buy forge actuator...
Looking to buy a forge actuator but don't know which spring and rod I need my car is standard apart from bcs exhaust ,gen2 filter,ggr manifold .
Can anyone point is in right direction
http://www.demonperformancecentre.co...s-mk1-forge-dv
Old Mar 21, 2014 | 11:08 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Ask on the RS Owners Club in the mk1 FRS section, you should get a few replies on there.
Old Mar 22, 2014 | 09:20 PM
PAUL JA's Avatar
PAUL JA
Standard turbo is straight rod, as for spring I think it's yellow if you are keeping the boost control solenoid or blue if you are going direct.
With those mods a map would make it drive so much better
Ring Pete at DPC he'll sort you out
Old Mar 28, 2014 | 03:12 PM
pauldonachyrs
Cheers mate
Old Mar 29, 2014 | 09:14 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I bought mine from Demon Performance last month. Will be running it direct so got a blue spring.
There's a guy on the RSOC forum that if you send your Forge actuator to him, he will modify it to make it easy to adjust as they are a bit of a bastard apparently!
Old Apr 24, 2014 | 09:18 PM
PAUL JA's Avatar
PAUL JA
You can buy an easy adjust forge actuator from filler phil on the RSOC forum
Old Apr 28, 2014 | 01:15 PM
alex_boy!'s Avatar
alex_boy!
yellow spring unless your going direct
Old May 28, 2014 | 08:19 PM
Matt Cooke's Avatar
Matt Cooke
What's involved in going direct?
Old Jun 3, 2014 | 11:24 AM
alex_boy!'s Avatar
alex_boy!
basically instead of running through the amal valve and controlled by ECU it's bypassed. Need a proper boost gauge to keep an eye on it and set it up
tankybaby66
Feb 6, 2016 02:24 PM
Fil
Sep 30, 2015 12:08 PM
muz
Sep 30, 2015 08:29 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
